Shuttle Shift vs Creeper Gear
/ Shuttle Shift vs Creeper Gear #1
mitchash
Greene, NY
Mahindra MAX 28XL, Jinma 254 (Sold)
When I was looking at new Jinmas at a dealer this weekend, I noticed they all had shuttle shift except an older demo model that had an extra low range, no shuttle shift. They told me they are only getting the shuttle shift models. What would be better? I am planning on using the tractor for loader work, plowing the garden, brush cutting, snow removal, moving dirt and gravel, making ATV trails, moving brush, etc. Is there a way to add a creeper gear to a shuttle shift model? Thanks, Ash
/ Shuttle Shift vs Creeper Gear #2
The current design is such that the case can only hold one set of gears, creeper or shuttle - not both. But with a little ingenuity, I'll bet you could buy a shuttle shift - then replace 1st gear with a granny low.
None of the applications you listed indicate a need for the creeper box though. I guess it's popular in the Chinese rice paddys, but over here it's use is pretty much limited to activities like roto-tilling.
//greg//
/ Shuttle Shift vs Creeper Gear #3
When I was shopping for mine, I asked the very same question as my nearest dealer was only ordering the shuttle shifts. I use my tractor as well as other tractors I have worked with over the years, for a little bit of everything you described(and a few you didn't:) and I personally wouldn't be without the creeper range of gears. I use 1-2 Low Low(creeper) for most of my brush busting with a 5' rotary cutter. Since the engine is running at full rated PTO RPM to power the cutter, your only control of speed is with the gears. In thick brush, and particularly on uneven terrain, going too fast can be real bad. The brush and tree stalks/trunks and stumps sometimes get where you don't want them and you can tear things up on the tractor or mower very quickly. Also hidden depressions and rises can pretty quickly turn what was an acceptable lean angle into an unacceptable one. It is good to be able to approach these things slowly and have a slow enough speed to be able to stop things before they get serious.
Your maximum traction force is applied at the slowest wheel speed. The ag tires need a little time for the tread teeth to depress into the soil, force it outward and get a bite. If you have too much wheel speed, the tires don't get a chance to bite and will spin. In creeper, when you come up against something that won't move, you can stop the tractor before the tires really start to dig in and do a lot of damage that you will have to smooth out.
Lastly, the creeper is great for fine positioning. A few weeks ago, I was confidently able to creep up and bring the Front End Loader with a new pellet stove setting in it, up to within a 1/4" of the threshold of my front door. I then shifted the stove from the FEL bucket to a dolly without lifting it. I just used it this last weekend to swap pickup beds between 2 trucks I am working on. The creeper allows that fine positioning and time to assess the situation before something goes crunch. It is also pretty handy for placing the post hole auger right on the mark.
If I was going to be doing a lot of loader work moving from pile A to pile B on level ground, or mow already cleared land, a shuttle's ease of shifting and higher reverse speed would probably be more desireable to me. For what I have to do, the creeper was the better choice for me.
/ Shuttle Shift vs Creeper Gear #4
I do the exact same stuff that you want to do. I have the shuttle shift and wouldn't trade for the creeper gear tractor. For loader work, the shuttle shift can't be beat. I don't have a 3ph tiller so that isn't a problem for me. It's all in what you want I guess. Good luck with whatever you wind up with.
/ Shuttle Shift vs Creeper Gear #5
this is one of the issues that have been debated pretty good in the past I suggest searching for them and going back over OLD posts, same info
anyhow if you plann on tilling land, with roto tiller a non-shuttle is needed, also for land leveling and busting new ground. if you are mowing & FEL work in open areas shuttle is way to go.
mark M
/ Shuttle Shift vs Creeper Gear #6
I've used mine to level land and to plow with (2-14" plows) without any problems, I haven't tried a tiller though.
/ Shuttle Shift vs Creeper Gear #7
I'm quite happy with first gear (Low Range) of my KAMA 354C Shuttle Shift. If it was any lower I would be going in REVERSE!
I do have occasional difficulty getting the bugger into any of the gears when the tranny is in Low range. Shifting gears is much easier in High range.
Anybody else notice a difference between Low and High range shifting ease?
If given a Third choice, I'd trade my shuttle shift for a syncronized tranny!
/ Shuttle Shift vs Creeper Gear #9
Rob,
I'm presently running 85/140. I think you hve a totally different tranny though. According to Chip's Web Site you have a constant mesh and mine is Spur gear.
When in Low range and Between gears it feels as if shaft on the Tranny side of the clutch is allowed to spin, even though clutch pedal is depressed. Because the Tranny shaft is still spinning the gears want to Grind before engaging. It also feels as if shaft is spinning much faster when in Low range.
The Clutch feels properly adjusted as there is only a small amount of Free Play at top of travel. If nobody else is experiencing this than I might try a bit tighter clutch adjustment. Don't want to ride on the throw out bearing though.
Tim
/ Shuttle Shift vs Creeper Gear #10
Tim After you adjust the free play on the pedal to an inch take the inspection plate off the right side of the bell housing and check the release levers distances to the throw out bearing. In your tractor operation manual pages 22-24 will help. It would be a good time to grease the throw out bearing too. I think your release levers need adjustment. There is a write up somewhere about the release lever adjustments. I just don't know where. Probably John's website. I have a ts354c and after adjusting the levers it shift good just some times I need to release the clutch a little to line up the gears. Kidney
/ Shuttle Shift vs Creeper Gear #11
I have done a bit of tiller work and low first gear is absolutely a fine gear for tilling virgin ground. I have used low range second gear for tilling where it has been previously tilled. With my Kama 554, their is no need for a creeper for tilling.
One thing I did do was to operate with the higher PTO speed and lower the RPM's to 1600 rather than 2200 . This gave me the lower ground speed and the correct 540 rpms for the tiller. The Kama has more than enough horsepower and doesn't even grunt even when going up grades.
The shuttle works better with the FEL as you go into a reverse at the same speed that you were going forward in. In my case, you have 8 forward and 8 reverse.
Six of one and half a dozen of the other. Some like vanilla and some like chocolate. I've not yet had the need to go slower.
/ Shuttle Shift vs Creeper Gear #12
I have A jinma 224 with a creeper gear. I also roto till . I have not used the creeper gear except for stump pulling . I till in first gear low range with no problem. Robby
/ Shuttle Shift vs Creeper Gear #13
I'm getting ready to buy a Jinma 254LE. My application will involve no tilling. It will include loader work, firewood, some personal landscaping, and maintenance of a 400' gravel drive. The plan for the long drive is most likely a 3PH snow blower. I know the shuttle benefits for loader work and the creeper for positioning, etc. I also know the creeper will give me more speeds. Which one is considered best for snowblowing in reverse?
/ Shuttle Shift vs Creeper Gear #14
i use a tiller behind a 284 jinma with shuttle shift. in first it is slower than my walking speed and is slower than my horse tiller. i ve broken plenty of new ground with it and the motor will barely notice the tiller is even hooked up. i dont really know why you would want go slower other than to eat time and fuel up
/ Shuttle Shift vs Creeper Gear #15
Yeah,you don't need a creeper gear to till.Get the shuttle,
/ Shuttle Shift vs Creeper Gear #16
I could not get by without the creeper gear. We do lots of logging and today the job at hand was to remove 5 apple trees with 14" plus stumps. Just cut them off at eye level then go around it with the FEL set 4' up and push on all 4 sides. Then get a chain up about 6" from the top and pull her over and have your helper use the chain saw to cut the roots. Could not do it without the creeper.
Chris
/ Shuttle Shift vs Creeper Gear #17
If you want a shuttle, you might want to take a look at the AgTrac. it offers a FULLY SYNCHRONIZED 8x8 shuttle. The Jinma is only 6x6 and non sychronized, and the AgTrac has direct mechanical linkage rather than a cable controlled shift. .. and wait, there's more! You also get a direct injection engine :)
/ Shuttle Shift vs Creeper Gear #18
Also its real nice to be able to go in reverse same speed as forward,saves alota time.
/ Shuttle Shift vs Creeper Gear #19
I've had a Jinma 284 for almost 7 years and the only thing I've ever used the creeper gear for is to stretch fence with. Pat
/ Shuttle Shift vs Creeper Gear #20
I took delivery of my new Jinma 284LE a week ago and have added 22 hrs to the clock but most was chipping. I've moved logs, removed small stumps/roots, and dug out some soil already. I'm certain the creeper is perfect for me. Most of the time the machine is in creeper, alternating with Low and High range. The work is all in the woods, gravel drive, meadow, etc. Yes I have a loader and use that as well...........I'm glad I bought the creeper but know everyone's need is different.
2020 Chevrolet Tahoe SUV (A60352)
2020 Chevrolet...
2015 Komatsu PC360LCLC-10 Hydraulic Excavator (A60352)
2015 Komatsu...
207272 (A52708)
207272 (A52708)
MULCHER (A58214)
MULCHER (A58214)
832719 (A61166)
832719 (A61166)
2023 John Deere 333G for Parts (A61306)
2023 John Deere...
