Shuttle shift transmission problems
   / Shuttle shift transmission problems #1
darsstars
Its been a while since I logged on here, mostly because I felt somewhat alone with my German JD 3400. I am sure there are a few still out there, should be mort cause they do so so many things good !
Now , here is my problem if anyone is listening who has an idea i welcome the mystery.... My 3400 has a shuttle shift trans. ( ZF ).that has started to slip in gear , sometimes a lot, . We checked trans pressure 200PSI rear, 100PSI front. So, rather than spending 10 grand, which I don't have right now, I decided to try changing fluid and adding Lucas Booster and Stop Leak. First I changed filter ( which looked very clean inside can ) then dumped what I thought would be 5 gal. of Trans. hydraulic oil.
What came out was 2 gal. total ! , yet the dip stick shows overfull ! ....so I proceeded to pour in new, strange thing only 3 gal. and I was showing over full again ! I took it for a spin around the driveway a bit , no slip , then tested again 3 gal. still showing on dip stick.I also had quite a bit of foam on dip stick. Waited an hour , checked it again, still same. Anyone know whats going on ? The book says 5.1 gal . I can only get 3 gal and start showing overfull?...strange.
   / Shuttle shift transmission problems #2
No model 3400 tractor shows up on JD's website. Foaming oil usually indicates a leak on suction side which introduces air into oil.
It sure does , not current as they stopped making them 5 years ago., but go to JD Parts and type in 3400 , comes right up. I know , the fresh oil was only in the trans for 15 min. when I shut it off to check dip.....and I see no leaks ether side, I must be missing something? Air lock ?
   / Shuttle shift transmission problems #4
I guessed I overlooked it the 1st time I punched it in. Danged old timers disease I guess. Advertised oil capacity of trans & hyd systems are advertised as total dry amounts which is hard to attain a totally dry system once oil has been added and circulated in the system.
   / Shuttle shift transmission problems #5
Wish I could help, but looking at parts diagram, it doesn't appear to be related to any model sold here in US. I didn't see any mention of shuttle shift in parts catalog either. Does the shuttle shift work without using clutch? Is there a suction screen in transmission that could be clogged? That could produce foamy oil also. Since pressure is lower in forward, that would point to a leak in the forward clutch.
Koyker Loader DoubleTine Bale Spear - Versatile for Round and Square Bales (A53473)
Koyker Loader...
7046 (A50322)
7046 (A50322)
Ford 18in. Stock Rims (A53117)
Ford 18in. Stock...
JOHN DEERE 560M LOT NUMBER 28 (A53084)
JOHN DEERE 560M...
2014 Chevrolet Tahoe SUV (A52377)
2014 Chevrolet...
