Shuttle shift F/R lever grinding
   / Shuttle shift F/R lever grinding #1
Thetylerguy101
Mahindra 3510
I own a 3510 shuttle. Recently, after the tractor warms up or is at anything higher than idle RPM the forward reverse lever grinds something awful when I shift. Any ideas what this might be? I have used this tractor for years and never heard anything like it.
Is this an expensive repair something that I can do easily?
   / Shuttle shift F/R lever grinding #4
Try adjusting your clutch first. The manual should tell you how.
I forgot to mention that I did try the clutch adjustment from .5 all the way out to about 2.5 and had the same grinding problem no matter the play. Wondering if I unbolt the housing that the lever leads to could there be a fork or something that's out of sync or alignment maybe?
   / Shuttle shift F/R lever grinding #6
As the first reply indicated. The synchros for the reverser shuttle are worn out.
When the fluid is cold and thick it acts as an additional friction element to the bronze synchronizer rings.
It's NOT an easy task to replace them. Break the tractor, pull the shuttle section down to pieces, replace the synchros (there is no "repairing" them. Then reassemble. It's not rocket surgery, but the parts can be heavy.
Thanks. Do you by chance have an idea of cost from a dealer to replace the synchronizers?
   / Shuttle shift F/R lever grinding #9
Dealer labor costs are location dependent and parts costs vary from manufacturer to manufacturer then also from dealer to dealer. Since you don’t list your location and I do not work at a Mahindra dealership what I think your repair might cost is irrelevant. Have a discussion with shops in your area.
   / Shuttle shift F/R lever grinding #10
Does it grind if you use the clutch? I’m wondering if it’s a pilot bushing and or throw out bearing- this would only apply if it was grinding when the clutch was depressed.
2004 Freightliner FL112 Cab & Chassis (A47384)
2004 Freightliner...
2003 Pierce Tilt Cab Fire Truck (A51692)
2003 Pierce Tilt...
Woods F21D Zero Turn Mower (A50514)
Woods F21D Zero...
2015 John Deere 5085M (A50120)
2015 John Deere...
Unused 2025 CFG MX12RX Mini Excavator (A50322)
Unused 2025 CFG...
Unverth - Brent Scale Wagon w/ Auger (A50515)
Unverth - Brent...
