Shredder Adjustment
/ Shredder Adjustment #1
texaslandman
Bronze Member
East Texas
Hinomoto E202, Kioti-LB1914
My friend just bought a used JD990 with a 6' JD shredder. Can some of you guys give us step by step advice and hints on hookup and proper adjustment of the shredder? Thanks.
/ Shredder Adjustment #3
The thread Bird referred you to may tell the whole story...but I did not feel like reading it again to find out... /forums/images/graemlins/blush.gif
The way I see it is that the tail wheel sets the height of the back, and the height of the 3PH set the mower height in the front...if it is the 3PH type and not the pull behind type.
So I would set the tail wheel to get the back at the approximate height I wanted the cut to be, and set the 3PH so the front was about an inch lower...or add an inch to the back...you know what I mean... /forums/images/graemlins/blush.gif /forums/images/graemlins/grin.gif
Fairly simple really when you think about it.
Good luck and be careful. Do a search or the archives and you will find a lot of important safety tips for rotary cutters...
2001 John Deere 1780 Planter (A63109)
2001 John Deere...
2017 FORD F-450 XL BUCKET TRUCK (A58375)
2017 FORD F-450 XL...
CAT 315F LCR Hydraulic Excavator (A61166)
CAT 315F LCR...
INOP/NON-RUNNING 2013 International DuraStar 4300 Box Truck, VIN # 1HTMMAAL0DH414751 (A61165)
INOP/NON-RUNNING...
2024 ANKONA 54" HANG-ON WHEEL LOADER FORKS (A62129)
2024 ANKONA 54"...
8087 (A61165)
8087 (A61165)
