Should my DK 45 have a trailer light connector?
   / Should my DK 45 have a trailer light connector? #1
StuartDK45SE
Angleton, Texas
Kioti DK45SE
2013 model. Seems like I have seen some literature in the past showing a 7 pin connector. I could use a convenient 12 v source for a foam marker I am planning on coming up with.
   / Should my DK 45 have a trailer light connector? #2
The DK and NX have cut out mount for the 7 pin plug on the rear right. Above the 3ph lever.
But I found out it was a dealer option. From my snooping around there are a lot of wires that look like this could be a plug and play install with a set of drawings.
2014 Dynapac CC4200 (A51039)
2014 Dynapac...
2008 LeeBoy 785 Articulated Motor Grader (A49346)
2008 LeeBoy 785...
2015 MACK GU713 (A50854)
2015 MACK GU713...
Tubing A500 Grade C 6in. SQ X 1/4in. X 28ft. (A50860)
Tubing A500 Grade...
UNUSED INDUSTRIAS AMERICA F08 - 8' LAND LEVELER (A50459)
UNUSED INDUSTRIAS...
3000 Gallon Black Poly Water Tank (A49461)
3000 Gallon Black...
