Should I wait to Change my filter and Fluid?
   / Should I wait to Change my filter and Fluid? #1
scsims
Central, KY
Mahindra 5525
I'm going to have an FEL and rear remotes installed on my tractor next week.
My tractor is due for it's 50hr service so I was planning on changing the UTF and filter today, but got to thinking would it be better to change it after the FET and remotes are installed or before?
Thanks,
Scott
   / Should I wait to Change my filter and Fluid? #2
Thanks,
Scott
yes, after. that way any contaminants introduced during the install are caught and removed.
   / Should I wait to Change my filter and Fluid? #3
Scott, I'd check my Operator's Manual closely. Most OEMs recommend a filter change at 50 hours to remove any manufacturing residue that may have collected in the filters. The actual fluid change is not needed until several hundred hours. You could be spending unneeded money.
2019 FREIGHTLINER M2 26FT NON CDL BOX TRUCK (A54607)
2019 FREIGHTLINER...
1999 CASE 721C WHEEL LOADER (A53843)
1999 CASE 721C...
2019 MACK PINNACLE P164T DAY CAB ROAD TRACTOR (A51406)
2019 MACK PINNACLE...
2015 Ford Escape SUV (A50324)
2015 Ford Escape...
2017 Peterbilt 220 16FT Box Truck (A51692)
2017 Peterbilt 220...
2018 DRAGON 150 BBL ALUMINUM VACUUM TRAILER (A53843)
2018 DRAGON 150...
