Mowing Should I mow in forward, or in reverse???
   / Should I mow in forward, or in reverse??? #1
kebo
Elite Member
Lexington, SC
2001 John Deere 790 4x4, bar tires
This is a new "Bi" set up and you can do it from the front, or from the back. Ok, enough kidding. I was just moving the bush hog on the front end to park it beside the road so people could see it better. I just thought it presented an interesting photo op. :laughing: Surprisingly, that Model 70 loader will pick it up rather easily, they are not known for being the most stout FEL. I think the factory rating is only like 800lbs, but I do have the shims installed to run the hyd pressure up to 2500 PSI, so that helps some. Oh yeah, for those of you local to the upstate SC area, the mower on the front is for sale. Inquire within. :thumbsup:
   / Should I mow in forward, or in reverse??? #2
You're doing it all wrong! They are supposed to be side-by-side, not front-to-back.
Unless your grass grows REALLY fast.
Bruce
   / Should I mow in forward, or in reverse??? #3
You gave me an idea! :D
I need to get a finish mower for the three point and make the rough cut from the front brush hog look smooth. :laughing:
2011 Land Rover Range Rover Sport AWD SUV (A48082)
2011 Land Rover...
2022 Ford F-150 4x4 Crew Cab Pickup Truck (A48081)
2022 Ford F-150...
Scraper USA Laser Tower (A50860)
Scraper USA Laser...
2013 Honda Odyssey EX-L Mini Van (A50860)
2013 Honda Odyssey...
2018 JOHN DEERE 204L WHEEL LOADER (A51242)
2018 JOHN DEERE...
2015 Ford F-550 Godwin 184U Crew Cab Mason Dump Truck (A48081)
2015 Ford F-550...
