Tiller Should I mount a coulter using shear bolts?
   / Should I mount a coulter using shear bolts? #1
scobrado
Bronze Member
Wilsonville, Ore. USA
John Deere 3038E
I bought a used 3 point Priefert bottom plow. I have ground with some blackberry roots, so I also bought a separate used coulter. The plow's moldboard is about 14" So I bought a coulter of 14" diameter with scalloped edges.
The coulter came with a mounting bracket, but I need two 1/2" bolts that pass through a 1" thick beam that runs parallel to the plow direction.
Should I buy shear bolts? If so, what rating? Or should I buy regular steel or hardened steel?
Thanks for the help.
--ScoBraDo
I bought regular steel bolts at the hardware store. Maybe I'm over thinking this. I just don't want to break the linkage on my tractor.
Let me know if you have any insight into this issue. Thanks.
CATERPILLAR 126" PIN ON BUCKET (A52707)
CATERPILLAR 126"...
2019 Dodge Charger Sedan (A55853)
2019 Dodge Charger...
2013 JCB 3CX Extendahoe Loader Backhoe (A55973)
2013 JCB 3CX...
204158 (A57193)
204158 (A57193)
VOLVO DD120B DBL DRUM ROLLER (A52707)
VOLVO DD120B DBL...
Ford F450 Bucket Truck with Altec AT200A Boom (A57024)
Ford F450 Bucket...
