should I buy a dump trailer?
   / should I buy a dump trailer? #1
GaryS
franklin park, pa
Kubota L3901 & LA525
In my search for a good used (or new) trailer, I came across this dump trailer for $2995. It's new and is the 1.5 ton version. Is that a good price? I had been just looking for a good utility trailer but wonder if it'd be worth price to go for the dumper.
The problem is that I don't have a set of jobs lined up for the dump - I can see that it will be useful down the road but it sure would be a tool in search of a project :) Is this something that I'll find all sorts of uses for and wonder how I ever got by without one?
   / should I buy a dump trailer? #2
I was looking for a dump trailer last year. A good used one was hard to find to find. I looked a 4 ton dump trailer new was $5000 , The more I looked at it the cheaper it was, single cylinder and the floor was quite tinny.Oh it also had 15 " tires. I found a 6 ton Bri-Mar, twin cylinder 16" tires and heavy metal for floors and sides, used I paid $4500. I have a 04 powerstroke and I need it when I get it loaded. I also bought an attachment for my 3 ph on my Kubota 4310 tractor that takes the receiver so I can hook it up to the tractor and I use it around the yard for picking up whatever, comes in very handy. I dont know if the $2995 for that trailer is a good price or not but I would definately by a dump trailer, very versitile. Oh I also haul my 6000# excavator on it and 2 4 wheelers and It is great if you help someone to move. And it is a labor saver if your wife wants some topsoil or mulch. Just my opinion but I would definately have one.
   / should I buy a dump trailer? #3
I recently build one, and I love it. One thing I'm concerned looking at the trailer above. I would not buy a dump trailer that sits on a single axle. Just my opinion.
   / should I buy a dump trailer? #4
Once you have a dump or tilt trailer, you'll find all sorts of uses for it. Unfortunately, my 22' Cam Superline is too light for my needs so I gotta sell it for a bigger one.
I was looking at the single axle for a couple of reasons - mainly cost and weight. Going to a dual axle really increases the price and the dual axle dump trailers are a lot heavy.
Do you say to avoid the single because it can't carry as much or are there safety/usage issues?
   / should I buy a dump trailer? #6
single axle-blown tire-BIG probem.
dual axle-blown tire-not so big problem.
   / should I buy a dump trailer? #7
I would say it really matters what you are going to carry with it . If you arent going to carry much then the single axle would be fine.
   / should I buy a dump trailer? #8
The latest greatest thing is the roll off dump trailer, that can convert to a flat bed also.
I just sold my 12K gump trailer as it was a double use product - dump and haul tractor, also the sides were so high on mine, my tractor would not lift over the edge, the sides were too high.
Whereas this beauty does a lot more. I can drop off a " roll off" on a job site, have a crew work that, drop off a second one with another crew, and then use the flat bed fo rall it's usefulness.
Here are a couple of systems, man are these cool.
http://www.berkelmanswelding.on.ca/roll_off_systems.html
http://www.pacificcompactor.com/products05/ezrolloff/index.html
   / should I buy a dump trailer? #9
I bought a 12k a few months ago and I love it !! I haul my tractor, gravel, rail road ties.. etc... I say go for the 1.5 dumper. You can do everything a utility trailer does and alot more. The dump feature alone is worth its weight in gold.
   / should I buy a dump trailer? #10
I just bought exact one you are looking at and it is great for its intended use-2000 lbs load.( 3 yards of mulch or one yard of dirt) 2995 is a going price. tows like a champ.If you want more capacity, there is a model that looks identical but has a 6000 gross weight.
2016 VOLVO VNL300 TANDEM AXLE DAY CAB (A52576)
2016 VOLVO VNL300...
2008 MAGNUM TRAILER LIGHT TOWER TRAILER (A52472)
2008 MAGNUM...
1273 (A50490)
1273 (A50490)
2019 Ram 2500 Pickup Truck, VIN # 3C6UR5DL0KG545677 (A51572)
2019 Ram 2500...
Redirective Crash Cushion Guardrail (A51692)
Redirective Crash...
CFG MH12RX Mini Excavator (A49461)
CFG MH12RX Mini...
