Should I bother with a lawn sweeper?
   / Should I bother with a lawn sweeper? #1
RayCo
Veteran Member
Chester County, PA
Kubota BX24, Case 580 Super L
About one acre of my property is grass, and that is all surrounded by woods, mostly tulip poplar trees. So, needless to say, there is constantly debris in my yard. For the most part, I just toss the sticks and things I find into the woods whenever I'm outside walking around. But the seed pods from the trees are way too plentiful for this. I could rake them all out, but that would get old quite fast.
So, I'm wondering if a lawn sweeper is something that is actually effective for such things. I'm talking about just little sweeper that I'd pull behind my lawn tractor, not some sort of PTO- or engine-powered vacuum. Would I just be wasting my money on such an item, or would it actually do a somewhat decent job of getting most of these things up.
I wasn't able to find a picture of the seed pods, but they're the ones that you might have split open and stuck to your nose as a kid. Either that, or you tossed them into the air to see them come down spinning like helicopter blades.
As for the lawn sweeper, it'd just be something like this.
http://bestlawnsweeper.com/wp-content/uploads/2009/07/Agri-Fab-38-Inch-Tow-Lawn-Sweeper.jpg
Thank you
   / Should I bother with a lawn sweeper? #2
I've got one (and in fact, it's an Agri-Fab, though an older model). Fills too fast, doesn't hold as much as it looks like it might, and mine has developed drive problems. Don't waste your time.
   / Should I bother with a lawn sweeper? #3
Ray, I wish that I knew the answer to the question. For I have the same problem with countless pine cones, assorted leaf types and a multitude of dead branches that come from Sycamores, Walnut and Pines. Especially when a big wind front blows thru, there is detritus from the roof down. For thirty-five years I've just hand picked the stuff up. But I'm old and tired now. It appears that the sweeper that you show would work only in limited circumstances. Larger branches wouldn't fit and the fall leaves would overwhelm the thing. I'll say this however, pickin' all that stuff up by hand sure has kept me lean ....and mean.
   / Should I bother with a lawn sweeper? #4
Unless you have a use for the clippings i.e. compost pile I'd say the best thing to do is leave the clippings on the lawn. It feeds the worms that fertilize your lawn that makes your grass grow and gives you an excuse for seat time.
   / Should I bother with a lawn sweeper? #5
Heres my two cents, once a year i dethatch my lawn and after i borrow a buddys sweeper. It picks up everything sticks, leaves, maple seeds ( aka helicopters) cig butts etc, works good for low volume . I also
have an 8hp Trac Vac which i use for heavy leaves, the sweeper would fill up too quick! Find a friend that has a sweeper and borrow it, good luck!
   / Should I bother with a lawn sweeper? #6
I sweep my grass clippings and leaves and place in a compost pile. Turn with the FEL every month or so. Anywhere between 8-12 44" sweeper loads every time I cut. You need room for a large mulch pile. Mine takes 12-18 months before it's usable. It can be adjusted to pick up everything but the larger sticks, these I usually mow over and sweep up the smaller pieces that are left. When sweeping leaves I also run them over first with the lawnmower, makes them pack a lot tighter in the hopper after they have been shredded a bit. Most sweepers are meant for smaller residential lots and won't last that long in heavy use. Pawl gears have had to be replaced every 3-4 years. Try to avoid any plastic drive parts. If you decide to get one, ensure all the drive components are metal, they will still wear out and have to be replaced, but cost a lot less. Usually it's the pawl gears that wear out, not the gears on the drive wheels. My present Agrifab Smartsweep 44" lasted less than a month before needing the plastic drive wheels replaced. Metal pawls and plastic gearing on the drive wheels are a bad mix IMO. I had an older 42" Brinly that worked well for years until the light tubular frame and hopper started to disintegrate.
   / Should I bother with a lawn sweeper? #7
I've had 2 sweepers. The 1st was cheap made and lasted about 3 years. The current came from Sears($300), is about 6 years old, has a larger basket than the Agri type pictured in the earlier post and works great. You just have to sweep and dump, over and over. If mine tears up, I'll go get another one.
   / Should I bother with a lawn sweeper? #8
Well worth it's it weight in gold and works like a :thumbsup:dream!
   / Should I bother with a lawn sweeper? #9
Jebster, What brand and model are you talking about? I need a sweeper as well, I've got two lawns to get lawn clippings and dog poo up. Will they do that? Any new reviews on the Brinley make? bjr
   / Should I bother with a lawn sweeper? #10
I have the largest Sears Craftsman equivalent to the one in your picture. It works great. Probably made by Agri-Fab.
2025 Forklift Safety Basket (A42742)
2025 Forklift...
7065 (A39855)
7065 (A39855)
2021 Chevrolet Express 3500 Police Transport Van (A42742)
2021 Chevrolet...
Freightliner 122 SD Truck (A42203)
Freightliner 122...
Bushog 6ft Disk Mower (A44391)
Bushog 6ft Disk...
2015 WESTERN STAR 4900 SF (A45333)
2015 WESTERN STAR...
