Should Coulters On A Ford 101 Plow Have Grease Fittings?
   / Should Coulters On A Ford 101 Plow Have Grease Fittings? #1
Utopia Texas
Platinum Member
Brookshire & Cat Spring,Texas
Kubota B2650 / Kubota L6060 / Kubota ZD2300
On the Ford 101 three bottom plow I just bought there are no grease fittings on the coulters. Were they there originally? Would drilling and tapping them for grease fittings be a good idea or is it necessary? The rolling landslide does have a grease fitting. Anyway to find the year made by the 7k serial number? Thanks...
   / Should Coulters On A Ford 101 Plow Have Grease Fittings? #2
According to the NH parts store exploded view, there is only on type of coulter that has zerks. Hopefully this link will carry through, and you can determine which one's you have. Object moved
6 STEEL KENWORTH T800 BUMPERS (A52472)
6 STEEL KENWORTH...
2014 D&P WELDING 16FT PRESSURE WASH TRAILER (A52472)
2014 D&P WELDING...
378583 (A51573)
378583 (A51573)
3 Point 36'' Lay Off Three Rows Plow (A51573)
3 Point 36'' Lay...
JOHN DEERE LOT NUMBER 123 (A53084)
JOHN DEERE LOT...
2021 Caterpillar 299D3XE Track Loader (A53342)
2021 Caterpillar...
