Ballast Should ballast in tires be removed when using BH?
   / Should ballast in tires be removed when using BH? #1
SnowRidgeME
Central Maine
Kubota B2920
Hi Folks,
My B2920 manual indicates that the ballast in the tires should be removed when using the BH. Anyone know why? Do you folks do that? Is it because of too much wait for the frame? I thought it was best to leave it in for stability / safety reasons.
   / Should ballast in tires be removed when using BH? #2
Mine for the BX24 says the same. I haven't removed it and don't intend to. Dealer says no problem.
   / Should ballast in tires be removed when using BH? #3
It would seem to defeat the concept of a "quick attach" backhoe if you have to drain & refill your tires each time.
   / Should ballast in tires be removed when using BH? #4
there has been a lot of talk about this in the fairly recent past, the consensus is pretty much that lots of folks with BH's load their tires and keep them loaded even with the warnings in the manual, I have loaded turfs on my B3030 and have a lot of BH time on it with no evident ill effects
   / Should ballast in tires be removed when using BH? #5
My dealer loaded my tires and never mentioned a possible issue with the BH....I can't see why it would make much diffrence other than giving you more weight to stabilize the tractor when using the BH.
   / Should ballast in tires be removed when using BH? #6
The key is to not load the tires over 60 - 75% with fluid. This allows the remaining air space to be able to compress somewhat without having the compressed fluid blowing out the tires.
Both my turfs and ag's are loaded and I haven't had a problem yet when I'm working the BH.
Thanks for the advice all. I was contemplating removing some ballast but as EX3200 said, kinda hinders the quick detach/attach. Was concerned with having so much weight on the stabilizers. Do you BH users lift the rears off the ground, or just a little to remove some weight off. Have not had much BH time yet, still tryin' er out. Just saw the post on the bent BH. My wife would be quited pleased with me if that happend this early.
Homemade Creep Feeder (A50515)
Homemade Creep...
UNUSED AGT MX15RX EXCAVATOR (A51243)
UNUSED AGT MX15RX...
2024 Ford F-350 Super Duty XLT FX4 - Like-New, Loaded, Only 780 Miles (A52128)
2024 Ford F-350...
TAKEUCHI TL12V2 SKID STEER (A51242)
TAKEUCHI TL12V2...
UNUSED FUTURE MINI SKID STEER PALLET FORKS (A51244)
UNUSED FUTURE MINI...
2016 CHEVROLET EXPRESS PASSENGER VAN (A51243)
2016 CHEVROLET...
