Shotgun range - distance
   / Shotgun range - distance #1
Welshman
Northeast Ohio
NH T1520
I'm planning to set up an area at my place for trap shooting (never done it before). Does anyone know of a chart or table to give me a fairly realistic idea for a safe "clear zone" for shooting a 12g. with 2 3/4" trap loads? I've looked at a number of websites and a somewhat general consensus seems to be 300 yards. That seems long to me (but what do I know?). I realize there would be a number of variables, but it seems that there ought to be some published estimates.
Thanks.
   / Shotgun range - distance #2
I don't have a chart...but the shot is going to go quite a distance, especially shooting up in an arc. I don't think 300 yards is unreasonable.
If you were shooting a flat trajectory, you could probably cut that range down by a third to half.
   / Shotgun range - distance #3
Having been on the receiving end of Thousands of rounds of 7 1/2 or smaller shot at a pistol range that was also a trap range up on the hill. When they were pointed our way (which was often) the shot rained down on us a lot. It seems to me it was about 350 maybe 400 yards away. But it was elevated at least 100 foot above us. You need to remember that the elevation angle of the shotgun is at times just perfect for maximum range on the shot. We always wore a baseball cap with a bill, and glasses. Never had a problem with the shot, but it was annoying at times.
James K0UA
   / Shotgun range - distance #4
250-300 yards is good - to be safe. I shoot clays on my place and with some of my shots across a pasture at 45 degrees, I can hear the shot going through the tree leaves at 300-400 ft. I shoot a 20 GA - a 12 GA will carry a bit further. If you're limited in available range, shoot from an elevated position (i.e., to aim down angle from 45 degrees - say 25 degrees or less).
   / Shotgun range - distance #5
James K0UA
I have been on the receiving end of this too. I would say 400 yards is the minimum. No doubt that trajectory plays a big part, but it would not be wise to take chances in my opinion.
   / Shotgun range - distance #6
It definitely depends on what shot you use, bigger stuff does go alot farther, so be careful of what shot gets shot if your range is tight. I had a little "range" setup to practice and pattern turkey shot, so I didn't worry about the angle of the hill behind my target. So when I was setting up for deer season months later, I just moved back to shoot slugs without thinking... 3rd slug must've skipped off a stone and went up over the hill as I could hear it ricochet and spinning for what seemed like forever... Ugh... Its a 1000+ yards to the nearest house in that general direction but I have no idea if it went 500 yards or 1500. After thinking some more I went for a drive to my neighbors place just to make sure nothing/nobody was hit... Nothing happened thankfully but I do have a different spot to shoot for slugs or the .22 now.
   / Shotgun range - distance #8
   / Shotgun range - distance #9
You should take the prevailing winds into account. Many years ago, we moved into a new development and there was a trap range to the North of us. It was far enough that the noise was not a problem, but with a strong wind out of the North, we would get a continual rain of pellets on our siding.
Thanks for all the good information. It's just what I needed, however it may be moot.
I was out experimenting a bit today, and at my present accuracy level, the only way I can hit the targets is to wait until they hit the ground, then run over and shoot them. It doesn't take much of a "safe zone" for that.:)
2015 FORD F-550 SUPER DUTY (A45333)
2015 FORD F-550...
VOLVO G720B MOTOR GRADER (A45046)
VOLVO G720B MOTOR...
2009 PETERBILT 367 TWIN PUMP CEMENT TRUCK (A45333)
2009 PETERBILT 367...
PT 1000 Gal Supply Tank (A44501)
PT 1000 Gal Supply...
Countyline Water Tank (A44391)
Countyline Water...
SKYTRACK 10054 (A45046)
SKYTRACK 10054...
