shortening a pto shaft
   / shortening a pto shaft #1
kmosabe
Bronze Member
Springfield MO-Ozarks
Yanmar 1300 Original/beautiful
Before I ruin a good shaft, what is the procedure for cutting a pto shaft to the correct length? How much overlap do you need. Do you measure the length needed from implement to pto when the implement is up or down or does it matter?
   / shortening a pto shaft #2
1. don't cut off any more than you have to, that will insure adequate overlap.
2. cut equal amounts off each shaft.
   / shortening a pto shaft #3
And shield.
Soundguy
   / shortening a pto shaft #4
Normally attach the equipment to the tractor then position the pto near the tractor pto shaft and measure from the end of the pto to the end of the pto shaft. (pto shaft fully compressed) then cut this ammount plus and extra inch from each end of the seperated pto shaft.
LOAD OUT INFORMATION (A53084)
LOAD OUT...
Roller (A52377)
Roller (A52377)
2014 Ford F-450 Altec AT200A 30ft Bucket Truck (A51692)
2014 Ford F-450...
2 1/2 Ton Military Truck, 6x6, 16' Flatbed (A52384)
2 1/2 Ton Military...
CAT D3 LGP (A50123)
CAT D3 LGP (A50123)
SHOPBUILT 40FT FLARE STACK (A52472)
SHOPBUILT 40FT...
