Shorten Skid Posts?
   / Shorten Skid Posts? #1
dougtrr2
Platinum Member
SW Iowa
BX24
I use a BX24 with a blade to move my snow. To set the height of the blade you stack up washers under the mount for the post. Currently, when I want to change the number of washers I have to raise the blade, then angle it to get enough clearance to remove the skid/post and adjust the washers. I can only do one side at a time. Not a big deal, but an annoyance.
It finally dawned on me if I cut an inch off each post and redrilled the keeper hole I would have enough clearance to adjust the washers without angling the blade. I can't see any downside as there is a lot of extra post. Am I missing something? The only issue I could anticipate is if the post is hardened. If it is I may give up on this idea. I would drill the new hole before I cut it off.
Appreciate the input.
Doug in SW IA
   / Shorten Skid Posts? #2
My plow truck is the same, I just drive it up on some 2x6 scraps to get me the clearance I need. Since I only do this about twice a year, it's not too much of a pain.
   / Shorten Skid Posts? #3
I worked with a guy from Iowa who mentioned several times how flat it was. I was going to suggest pulling the tractor up to a place where the ground dropped of a bit:)
Okay, over 100 views and no screams from the safety police and no one has said there is a hidden flaw to my plan. But, the two responses I did get gave me a forehead slapping "DOH" moment. My driveway slopes up to the stall I park my tractor in. I may be able to pull out to the edge of the garage and have enough clearance.
Doug in SW IA
2015 CHEVROLET CAPRICE POLICE CAR (A51222)
2015 CHEVROLET...
2016 Ford Fusion Sedan (A50324)
2016 Ford Fusion...
1273 (A50490)
1273 (A50490)
IH Farmall 706 Tractor (A50514)
IH Farmall 706...
2007 Case IH 2588 4WD Combine (A50657)
2007 Case IH 2588...
1266 (A50490)
1266 (A50490)
