shorten pto drive shaft
   / shorten pto drive shaft #1
diesel466
western n.y.
Kubota L2502
I just got a new woods mower and need to shorten the pto shaft, My problem was the female tube half has a collar welded near end to support the outer safety shield. You cant cut the end off without getting into that collar, SO can I press the yoke off the other end and shorten it that way? It is a comer brand shaft. Anybody run into this before? Thanks
   / shorten pto drive shaft #2
Have you asked the dealer to trade you for a shorter shaft?
If it was me and I had to work with that one, I'd cut it on the other end or take some out of the center section so all your hardware is in place where it is needed. Usually drive shafts are balanced. Mark the shaft so it wont get turned, make sure the two cut off sections are mated back together without turning either piece. And pay attention trying to not let your weld get thick in places making it off balance. You may not be perfectly balanced but I think it would be close enough.
The two halfs slide into each other no welding required, These shafts are shorted all the time, this one just has a collar that I have not seen before.
   / shorten pto drive shaft #4
I second the recommendation to simply trade it for a shorter version
//greg//
I got the driveshaft cut down today works great. Thanks
JOHN DEERE XUV835M LOT NUMBER 26 (A53084)
JOHN DEERE XUV835M...
New Wolverine 3pt Receiver Hitch (A53002)
New Wolverine 3pt...
Godwin CD150M 6in Dri-Prime Pump S/A Trailer (A51691)
Godwin CD150M 6in...
2024 BCL Fabrication Landscape Dump Trailer - Heavy-Duty Utility Trailer for Mulch Debris Hauling (A53472)
2024 BCL...
(1) HD 24ft Free Standing Corral Panel (A51573)
(1) HD 24ft Free...
2005 International 4200 Texoma UC-301 Pier Drilling Truck (A52377)
2005 International...
