CH4Ohio
Veteran Member
I just installed the WR Long 3rd Function Kit on a cab model Kubota L5740. Seems to work great and installation is pretty straightforward.
However, because the new joystick knob with button sits a couple inches higher it now seems like the joystick handle is just way too high. I haven't seen anyone mention the need to lower or shorten the joystick as part of the 3rd function addition.
Just wondering if anyone has found the need to cut the joystick rod to lower the knob/handle after adding an aftermarket 3rd function???
(There is a little bit of adjustment using a locknut on the bottom of the joystick so I gained close to a half inch there already.)
Thanks.
Thanks.
