Short_D ..... Long_D on Display? 3320?
   / Short_D ..... Long_D on Display? 3320? #1
CAgnoli
Kiantone, NY
Kubota Grand L 3940 HST-3
I often see the above on my digital display. What is it referring too?
Thanks!
   / Short_D ..... Long_D on Display? 3320? #2
I believe those are associated with the rollout settings of the MotionMatch feature.
   / Short_D ..... Long_D on Display? 3320? #3
From your 3320 manual;
   / Short_D ..... Long_D on Display? 3320? #4
If you have the motion match switch you can have two settings. One for long and one for short. You program the switch by using the turn signal switch to change the setting number.Short settings are 1 thru 5 and long settings are 5 thru 9. Don't know if 5 short and 5 long are the same. Number 5 is the factory def setting. I thought with the motion match switch you could use it to scroll thru the number settings and change it with the motion match switch. You can't. You have to change the number setting with your turn signal switch. After setting the number you desire the motion match switch gives you the choice of long or short. Say short is set at 3 and long is set at 9. Then you can change between the two with the motion match switch. If you want to change number settings you have to go back thru and reprogram it.
2003 Lexus LS 430 Sedan (A50324)
2003 Lexus LS 430...
City of Lakeland (A51691)
City of Lakeland...
2018 Ford F-150 4x4 Crew Cab Pickup Truck (A50323)
2018 Ford F-150...
2016 Kia Cadenza Sedan (A51694)
2016 Kia Cadenza...
NEW Wolverine Skid Steer Trencher (A53002)
NEW Wolverine Skid...
2013 FREIGHTLINER M2 ROUSTABOUT TRUCK (A52472)
2013 FREIGHTLINER...
