I had to let my 2210 sit out in the weather most of last summer. It got a short in the signal light. The right one stayed on all the time blinking When the switch was in the off position The left light was on but not blinking. If I turn the left light on they both stay on but don稚 blink. When I turn the other light switch it don稚 change the signal lights. I can稚 get both lights to blink at the same time. After I finished the other job I was doing in the garage and put the tractor back into the garage I was going to take it apart and find out what was wrong. I started taking the dash apart but had to remove the steering wheel. I stopped for the day. I went back the next day and everything was working like it was suppose to. Everything was fine through a couple washing then the last time I washed it the problem was back. I parked it in the garage and after a couple days it was OK.
My question is witch switch is the problem. Do I need a new switch or can it be sealed? I don稚 worry about the caution in the summer but I do like them when I知 blowing snow.
Thanks in advance for any help you can give me.
Charlie
Charlie
