Posthole Digger Shopping for a post hole digger
   / Shopping for a post hole digger #1
oldgoat2
Bronze Member
South Central Kansas
2005 Kubota L3400HST
My first impression is you get what you pay for in the head units. Are any brands better at the actual digging than other brands. This question would mostly pertain to the auger and bits. For all I know the augers may all be made by the same manufacturer since the mounting seems to be standardized. So far my choice is the TSC model since my work will all be light duty.
   / Shopping for a post hole digger #2
I have a PHD very similar to the TSC model (could be the same manufacturer) and it works quite well for light duty, as long as the soil isn't to rocky.
Well here is what I have learned since yesterday. I ran into a local ranch hand at the coffee shop this morning who does a lot of fence building. He said all 3 point posthole diggers dig the same. If you spend more for a heavier model, it will last longer, will handle hitting rocks, roots etc better, and will accept the really wide augers (over 12"). If you spend more for a national brand name model, you have a better chance of finding repair parts later down the road. But most importantly, he said the trick to making any posthole digger dig holes in all conditions is to find and install tips called rock tips or frozen ground tips. They are the same thing but marketed differently depending on where you live. Sometimes they are not easy to find but well worth the trouble. I think he answered all my questions. Hope this information helps other as well.
   / Shopping for a post hole digger #4
Reading your previous post answers the question:
Can an old goat learn new tips?
Seems the answer is yes. Additionally a new 3720 owner learned
a lot too. Thanks!
Steven
   / Shopping for a post hole digger #5
I have the TSC one with a 12" auger and it works pretty good. I have also used a Danuser with a 14" auger and that thing was sweet but costs around 3 times as much as the TSC model so it wasn't that sweet. /forums/images/graemlins/grin.gif
TSC had two models, the standard and then they had the heavy duty which was almost twice as much and I ended up with the standard and with the 12" auger it cost me about $550 including tax. If I had it to do all over, I would buy the TSC one.
   / Shopping for a post hole digger #6
My friend purchased the TSC and used it for a bit before he thought to check the gearbox and discovered it was shipped dry. /forums/images/graemlins/frown.gif He filled it and it has been fine. /forums/images/graemlins/smile.gif
Just thought I would mention this as a heads up.
   / Shopping for a post hole digger #7
I've had just dandy service from my Leinbach PHD & augers, I have a 9" and a 12". I've abused the 12" many times in creekbed with some really big rocks turned up and it still bores a good hole. Never a problem with gearbox or driveshaft. I'd buy another. I think my cost on the PHD and 2 augers was around $600.
I wound up getting the TSC post hole digger with a 12" auger. They had a 10% off managers special on it the weekend so the cost was $460 something. He even through in the display stand! Kinda bent but several feet of nice flatbar looks like gold to an old cobbler /forums/images/graemlins/smile.gif. There is a sticker on the gearhead warning of no oil and to add so 90W. Thanks to all for the advice.
   / Shopping for a post hole digger #9
I've read from many that the PTO driven PHD's can be a problem in rocky ground. Without a reverse the auger can get jammed (stuck) and you have to manually back it out. /forums/images/graemlins/frown.gif
That does not sound like the reason I purchased my CUT. The idea is to do less hand work.
Any experiences with this?
Should this be a real concern?
Gary
   / Shopping for a post hole digger #10
</font><font color="blue" class="small">( I've read from many that the PTO driven PHD's can be a problem in rocky ground. Without a reverse the auger can get jammed (stuck) and you have to manually back it out. /forums/images/graemlins/frown.gif
Gary )</font>Depending on your soil, they can be a blessing or something to curse at. I have never researched the exact makeup but my soil is clay like with brown shale like stones. With little give to it, even the smallest of stones can make the auger just sit and bounce.
Since the 3ph relies on weight for down pressure, you develop a feel for the correct amount of throttle and down pressure while watching the auger. Generally, if I am able to dig with it, I will load up the auger with some dirt, pull it up an inch or so then lower it to load it some more until I get it pretty loaded up. I find it less likely to get stuck if I load it this way rather than to just keep it digging without pulling it back a bit every now and then.
Depending on the moisture level, I will increase my auger speed while I pull it out of the hole to spin the soil off and try to prevent it from dropping back into the hole although some invaribly will. Then I will go back into the hole repeating the procedure until I reach the depth I want.
I go down three feet to set an eight foot post or four feet for a ten foot post depending on the application. You get stuck that deep, well, it can be tough to get it backed out. I grab the four foot pipe wrench and back it out with that. Sometimes I add the cheater bar.
I have to clean at least some soil out of the hole by hand then I tamp and perhaps throw some soil back in until I get my correct depth within an inch so the posts look uniform. If I have a lot of posts in a line, I set the corners, stretch a line and mark off the position with paint.
You may need to adjust the tractor position as you dig to keep the auger vertically aligned. Stones can make the auger go ascew too so it is sometimes difficult to keep the hole where you want it, especially working alone.
Most of my fence posts were pounded in. It is amazing to see a blunt post driven into the ground where it would take you an hour to dig one hole! It is expensive and requires enough work to get the company out to drive the posts though. With enough changes or additions to the fence, I find the auger worth having around.
I also use it to prep for tree planting. I use it to tear up ground hog holes so I can tamp them in properly (until the little rascals come back).
Like any tool, you need to consider expense and usefulness based on your land and needs.
2004 MACK GRANITE CV713 DUMP TRUCK (A51406)
2004 MACK GRANITE...
MAXUM 1000 TRIPLEX PUMP POWERED BY 3412 CATERPILLAR ENGINE (A50854)
MAXUM 1000 TRIPLEX...
1999 Ford F450 Dump / Plow Truck (A50514)
1999 Ford F450...
2020 Cat 299D3XE Skidloader (RIDE AND DRIVE) (A50774)
2020 Cat 299D3XE...
Lay-Mor Sweepmaster 400 Broom Sweeper (A49461)
Lay-Mor...
2015 CATERPILLAR 326FL LONG REACH EXCAVATOR (A51242)
2015 CATERPILLAR...
