Shop in use at last!
   / Shop in use at last! #1
Boondox
Elite Member
Craftsbury Common, Vermont
Deere 4044R cab, Kubota KX-121-3S
Got the sheetrock hung, the wiring completed, the power tools back, the lighting all set, and am beginning to build shelving and cabinets to hold all the stuff. The only problem so far is with my Delta 15" planer. I have to fire up the woodstove and let the planer warm up for several hours before trying to use it, otherwise the cold belt is so stiff the breaker trips. Ah, woodworking in New England!
The other thing I noticed is it's a bad idea to stand under the eaves or to put anything there. With that metal roofing, when the snow lets go it ALL comes down with a resounding THUD!
But it sure is nice to not have to rake the roof anymore! /forums/images/graemlins/grin.gif
Pete
   / Shop in use at last! #2
I'm sure you'll get lots of use out of the new shop Pete. I sure hear you on the cold shop tools front though. I had a flat on the front tire of the Kubota (nother issue /forums/images/graemlins/mad.gif), but in order to fire up the compressor I had to set a small heater next to the compressor motor and warm it up. Oh to have a nice heated garage!!!
Kevin
   / Shop in use at last! #3
<font color="purple"> Oh to have a nice heated garage </font>
Here in AZ, that's the only kind of garage there is /forums/images/graemlins/tongue.gif
   / Shop in use at last! #4
Hank, I here you. I'm trying to figure out how I can afford to air condition my barn, not heat it...
   / Shop in use at last! #5
Glad to hear the shop is done Pete, Yea don't stand under the eves it can get dangerous with snow and ice.
Take care and I'll have to get up there after sugaring to see it.
   / Shop in use at last! #6
Good oh Pete:
I'd be very happy with a garage. The basement workshop is rather small.
Egon
   / Shop in use at last! #7
Hey! /forums/images/graemlins/laugh.gif
Congratulations on getting it "workable"! /forums/images/graemlins/cool.gif
That's got to be a big relief. If you have one of those halogen work lights, you could turn it on and put that next to your planer to warm it up. I use one of those on my torneau cover on my pickup in the cold weather. When I take the cover off to haul something, I can't stretch it enough to get it re-snapped. I just turn on the light and lay it on the cover aimed toward the back edge, and after about an hour I can stretch the cover enough to get it to snap. I bet it wouldn't take that long for the light to warm up your planer! /forums/images/graemlins/wink.gif /forums/images/graemlins/smile.gif
That's a great idea, Garry! I have a few of those halogen lamps, all burned out, but have been meaning to get more bulbs anyway. Now I have an excuse!
It warmed up all the way to 33 degrees today, so late this afternoon I finally mounted the sub-panel in the garage and backfed the 220 cable. So now I'm not dependent on that single 15 amp 110 circuit running nearly 100' from the breaker box all the way to the far end of the garage! Had all the garage lighting, outlets, garage door openers, security lights, electric fencing and the livestock water heaters running on that one circuit...and now those days are over! Yipee! /forums/images/graemlins/grin.gif
Pete
   / Shop in use at last! #9
Alrighty Then! /forums/images/graemlins/laugh.gif
So when's the VIRTUAL TOUR going to be posted?! /forums/images/graemlins/shocked.gif /forums/images/graemlins/smirk.gif /forums/images/graemlins/grin.gif
   / Shop in use at last! #10
Pete:
The new power supply just might make starting them relucutant high draw items a thing of the past. Are you gona switch over to 220 for some of the larger motors?
Egon
Case 1083 20ft Corn Head (A55301)
Case 1083 20ft...
2018 Ford Fusion Hybrid Sedan (A53424)
2018 Ford Fusion...
300# CLUTCH JACK (A53843)
300# CLUTCH JACK...
1996 LUEHAUF TRI AXLE STEP DECK (A53843)
1996 LUEHAUF TRI...
35176 (A53424)
35176 (A53424)
7021 (A50322)
7021 (A50322)
