Osconda
- Joined
- Apr 14, 2005
- Messages
- 184
- Tractor
- New Holland TC55DA, delivered 05/25/2005
TC48 owners can probably give some feedback here also.
I have the EHSS option on my tractor if it makes a difference. When shifting gears it appears to me that the shifter is very stiff although the only reference I have is shifting gears on a truck. I feel like I have to use more force than necessary to shift into 1st gear. I'll qualify it this way, if my wife was trying to shift the tractor into first she wouldn't be able to do it without leaning into the shifter.
Is this something the dealer can adjust?
Also, can the dealer adjust the range shifter? I never have trouble changing into medium or high range but shifting into low range some times leaves me out of gear. I realize that when I put the shuttle into forward and nothing happens. Then I put the shuttle back into neutral and wait a bit so as not to grind any gears and securely put it into low.
I've only got 29 hrs. on the tractor so I'm not sure if I'm just not used to it yet or whether I need to get it looked at. I might stop by the dealer and check out how the other models feel when shifting.
I hate taking it back in and being without it if it's something I can adjust myself.
