Mowing Shifter stuck in high gear
   / Shifter stuck in high gear #1
hcody
Kubota MX5000
Have a 2006 Kubota MX5000. Yesterday was shredding and got on county road to get to other section of property.
Shifted from low to high(pretty sure I came to a complete stop).
had some resistance but got it to go to high. Can not get it out of high.
Was able to shift the other transmission gears(1-4)
Had to park, now of course can't
start it. Did get it back to shed before shut down.
Any suggestions what happened and where to go from here?
Thank you.
   / Shifter stuck in high gear #2
This sounds a little different than my L3400dt, when mine sticks in gear, I cant move the L H range lever or the 1-4 shifter. My clutch and presure plate is what causing my issue, I have to hold the brake down and jerk the clutch pedal to get it out of gear. Sounds like your problem is in the L H range area only, I'm assuming yours is a gear tractor. Good luck.
   / Shifter stuck in high gear #3
I had trouble with my l4400 when a stick got jammed underneath in the linkage while pulling logs. I had to loosen the bolts and readjust the linkage to get it working. Works fine after doing that.
Rhino FS15 Flex-Wing Rotary Cutter - 15 Ft Heavy-Duty Brush Hog for Pasture and Roadside Mowing (A52128)
Rhino FS15...
71069 (A49346)
71069 (A49346)
Kuhn SR108 Speed Rake (A50515)
Kuhn SR108 Speed...
2016 GENIE GTH1056 TELESCOPIC FORKLIFT (A51242)
2016 GENIE GTH1056...
Land Honor Skid Steer Tree Puller (A50515)
Land Honor Skid...
