shifter lever roll pin
   / shifter lever roll pin #1
gatekeeper2
kooskia
ford 9n
I have FORD 9N 1947 YEAR. SHIFTER LEVER IS LOOSE AND THE ROLL PIN IS BROKE. How can one remove the broken pin. I have a new one for replacement . The top plate of transmission has the four bolt and looks like it emcompases the steering wheel mechanism.
   / shifter lever roll pin #2
you will likely have to drive or drill the old pin out. also look at the top area on the cover the pin rides. if it is wallowed.. i'd duild up.
if an aluminum cover.. tig it. if cast. braze it.. or weld.. your choice...
check out the expanded aprts diagram in your parts manual.. or from the online parts web site..
5K BLOWOUT PREVENTER (A50854)
5K BLOWOUT...
2017 DITCH WITCH RT30 RIDE-ON TRENCHER (A51242)
2017 DITCH WITCH...
2025 Kivel 48in Forks and Frame Skid Steer Attachment (A50322)
2025 Kivel 48in...
2025 Swict 84in Bucket Skid Steer Attachment (A50322)
2025 Swict 84in...
2020 John Deere 3032E Tractor Loader Backhoe (A51243)
2020 John Deere...
SCAN TO RECEIVE TEXT UPDATES (A51242)
SCAN TO RECEIVE...
