dlrides
Owned this tractor for a few years, never any issues. While bush-hogging a few days ago the TPH starting lifting slower, then stopped lifting at all. I can make it lift with no rear attachment, at full throttle only. The FEL works fine, so I think the hydraulic pressure is good. Hydraulic oil is fairly fresh, and level is good. This tractor has the solenoid activators with a manual overide lever, acts the same with using both. I have no manual or drawing to determine the lift cylinder construction.
) At this point it seems to be "blow by" in the lift cylinders, sound correct ?
) If so, does it have o-rings, seals, or other ?
) Where can said parts be found ?
Any help would be much appreciated.
Don C
Don C
