My headlight burnt out. I drive a Dodge Dakota quad cab.
After checking the manual I went out and picked up the lightbulb.
Once back home I started the replacement process. The manual was short and useless. First I needed a Torx driver. After un-doing that I needed a large flat screw driver to undo the quick connects to the turn signal unit. There was no slack in the wires so I used the screwdriver to pry off the connectors. I could then remove the turn signal unit.
Next I had to remove the headlight and its' housing. This required a 10 mm socket and 10 inches of extensions to reach the 3 nuts. What a pain. I replaced the bulb and then re-assembled eveything.
In all it took about forty minutes. If I didn't have a Torx set and extensions for my socket set I would have been stymied. Changing a lightbulb should not be so hard.
The conspiracy theorist in me thinks they do this by design so the average owner will take it into the shop to get replaced.
Phil
Phil
