Sheep tractor ???
   / Sheep tractor ??? #1
shinnlinger
Canaan, NH
Kubota L2850
Hi,
I built a "sheep tractor" this spring using (4 )30 ft telephone poles as a base, but it self destructed over time due to a bad design on my part. BAsically I thought allowing the corner joints to flex so it conformed to the land was a good idea so I attached each corner with a short length of chain thru bolted into each pole. I then drilled into the poles and drove rebar every 5 ft ot so for posts and attached sheep fencing to that. Over time it flexed too much and the fencing began to lay flat when I moved it.
It worked really well for grazing though as the sheep and goats ate everything in marginal pastures down to the ground and I could move it myself in 5 minutes with the tractor. I think making fixed corners is going to be better and have some ideas that involve a chain saw and some reinforcing timber, but the stresses on a joint for such a large unit (30 x 30) would be alot. Any ideas there?
Alternately I would make narrower units that were 10 x 30 and pull them from the short end. I could see having several of these units and at feeding time I would just go drag the different units around.
   / Sheep tractor ??? #2
New Hampshire sounds like a much better place to raise sheep than northeast Texas. I think your sheep tractor idea would work here if I could varmint-proof the sides. Stray dogs are the main culprit, but Mexican buzzards also cause problems. Stiffen those corners any way you can, but the main consideration is cost.
Butch
2014 Therm Dynamics TD400 Towable Flameless Heater Trailer (A49461)
2014 Therm...
Cruise Car Electric Golf Cart (A50860)
Cruise Car...
2025 8ft Office Shipping Container (A49346)
2025 8ft Office...
2005 International 8600 Hydro Vac Truck (A50860)
2005 International...
SCAN TO RECEIVE TEXT UPDATES (A51242)
SCAN TO RECEIVE...
2025 Man Basket Forklift Attachment (A49346)
2025 Man Basket...
