Shed Rebuild
   / Shed Rebuild #1
Bwana64
Bronze Member
Harris & Fayette Counties, TX
Kubota B6200, MF 230, JD 4240
Well, my old wood shed with tin roof has had it. I need to replace it as the roof is almost completely gone. It is over 50 years old. It is only 20'x24' and has a concrete floor. Question is: rebuild with wood and tin, or buy some prefab metal deal? I like the idea of no-rot, but price is of major importance. Anyone got suggestions or experience?
   / Shed Rebuild #2
Partly depends on what you are going to use it for, how comfortable you are doing construction and how much time you have.
You can get a metal building kit in the 3K-5K range (depending on your options).
   / Shed Rebuild #3
If the frame is solid, no question, just put new metal on. Assuming you can do it yourself, which is a pretty easy job on a building this small, the cost is not high. Depending on how much lumber you have to replace, the roof will run about $750 or less. You didn't mention how tall it is or what type of doors it has, but new metal siding should be well under $1000 and the shed will look like a new one.
2017 Ford Explorer AWD SUV (A54815)
2017 Ford Explorer...
UNUSED LANDHONOR LHR-DFP10 DSL FUEL TRANSFER PUMP (A54757)
UNUSED LANDHONOR...
2017 TROXEL 130 BBL STEEL VACUUM TRAILER (A53843)
2017 TROXEL 130...
Bomag BW 211D-3 (A47477)
Bomag BW 211D-3...
197711 (A51244)
197711 (A51244)
2023 54' Hooklift Dumpster 20 Cubic Yard (A53422)
2023 54' Hooklift...
