Shearng the bolt pin on bush hog with John Deere 990
   / Shearng the bolt pin on bush hog with John Deere 990 #1
pianokey50
Bonaire
John Deere 990
Does anyone have any tips on what I could look for with reference to the following: I have a John Deere 990 Tractor. Almost everytime I try to use the bush hog, when I go to engage the PTO, the bolt pin shears. Thanks
   / Shearng the bolt pin on bush hog with John Deere 990 #2
Are you trying to engage at idle speed?
   / Shearng the bolt pin on bush hog with John Deere 990 #3
How worn is the shaft or part the shear bolt fits into . And agreed as Tx Jim suggested to idle engine then increase speed and bush hog increases spin.
Proper sized bolt also not hardened .
ken
   / Shearng the bolt pin on bush hog with John Deere 990 #4
Idle speed is probably the key... But do lift the cutter and look under it in case there is something blocking the blade, like a piece of bent metal. Try to turn the blade by hand. If it doesn't turn freely than it could be frozen for a number of reasons.
But you are probably just engaging it at full rpm.
Hy-Brid HB-1030 10ft Electric Scissor Lift (A50322)
Hy-Brid HB-1030...
Komatsu PC56 Excavator (A51573)
Komatsu PC56...
2015 Kenworth T400 T/A Vactor 2100 Plus Combination Sewer Jetter Vacuum Truck (A50323)
2015 Kenworth T400...
2013 Mack GU713 T/A Vac-Con Combination Sewer Jetter Vacuum Truck (A50323)
2013 Mack GU713...
2010 Honda CR-V Multipurpose Vehicle (A51694)
2010 Honda CR-V...
2016 Kenworth T880 T/A Vactor 2112P-16 Combination Sewer Jetter Vacuum Truck (A50323)
2016 Kenworth T880...
