Shearing bolt on pto gear box,grasscatcher
   / Shearing bolt on pto gear box,grasscatcher #1
BobG116
North Central Ohio
BX1830
I have a BX1830 tractor with a grass catcher GCK60-BX. After using the grasscatcher for about an hour the bolt breaks and I have to replace it. This has happened quite often. When installing the catcher it is as level as one can get it. When engaging the catcher I do this at about 3/4 throttle. I asked the dealership about this and they say I'm the only who has purchased a grasscatcher and therefore they are not familiar with the problem. Hopefully someone on this site can shed some light as to what is wrong. Thanks for your input.
   / Shearing bolt on pto gear box,grasscatcher #2
Use 1/4 throttle or less when you engage the mower and no more sheared pins- The higher speed is enough to break the shear pinwhich is what it is designed to do for you if you smack an object with a blade.
2025 New/Unused LandHero 1 in Air Impact Wrench (A51573)
2025 New/Unused...
2017 Nissan Frontier Ext. Cab Pickup Truck (A51692)
2017 Nissan...
2010 PETERBILT 387 TANDEM AXLE SLEEPER TRUCK (A52576)
2010 PETERBILT 387...
2018 Sakai SW990-1 Tandem Vib Roller (A52384)
2018 Sakai SW990-1...
2018 John Deere 6215R MFWD Tractor (A53342)
2018 John Deere...
