Mowing Shear bolt
   / Shear bolt #1
jacobsdaddy06
Bronze Member
NW Arkansas
MF1240
Bought a used big bee agri five, hog does anybody know what grade bolt this thing uses, I've tried 2 and it shears on grass, or when I first engage pro (at low rpm) Thanks
   / Shear bolt #2
Generally shear bolts are grade 2, you want them to be the weakest link so they help protect the PTO gears and driveline parts. I don't know that I would advise going to a stronger bolt. Maybe you should try getting a slipclutch and see how that works for you? They cost about a $100 or so.
   / Shear bolt #3
They are usually grade 2 bolts. Have you got the correct diameter of bolt?
   / Shear bolt
Yea I have I thought about a slip clutch, yes they are the same size as the one I sheared after I bought it. Grade 2 is what I bought for it, good thing I bought a bag full..
   / Shear bolt #5
Does the collar fit the shaft well? If so, and youre shearing as easily as you say, its likely that the shear is made for Gr5. Grade 5 shears at a higher level, but shears more cleanly tha Gr2 which is kinda gummy by camparison. Never go above Gr5 because Gr8 will damage shaft and collar.
larry
   / Shear bolt #6
A slip clutch is the way to go. Swapping out shear bolts is a pia.
How about a grade 5 in a smaller diameter?
   / Shear bolt #7
You should ask big bee agri five about the correct shear bolt size.
I bought a Salsco chipper, made in CT, and replaced with an Imperial dia shear bolt. I felt a little play and several sheared in low-load conditions.
After calling Salsco, they advised me that the shear bolt should be metric - i.e. made in US for both American and other export markets; other markets don't have imperial bolt sizes readily available.
Works fine since.
   / Shear bolt #8
If you have - or can find a copy of - the manual, it should specify. My Deere brush hog uses a grade 5 - which I bought used and had to get help from fellow TBNers and other internet searching to figure it out. The dealer tried to tell me grade 8(!). Glad I didn't listen. So you can ask the dealer, but also use common sense, they may be well intentioned but off the mark...
   / Shear bolt #9
Land Pride shear bolts are grade 3 and they recommend using grade 5 if it shears too often. They caution against grade 8. I have a clutch on my RT and am about ready to junk it and replace w/ a shear pin. I have to disassemble the clutch twice a year, clean it up, and reinstall. Takes an hour of cussing to get it done. A little rust on the plates (it rains a lot here) and they do not slip anymore. I have a lot of big rocks in the garden spot. Hopefully I am getting them all dug out. I carry a 3' crowbar to work them out. My LP hog has a shear bolt and never sheared last year.
Ron
71052 (A49346)
71052 (A49346)
2018 John Deere 470G Hydraulic Excavator (A50322)
2018 John Deere...
2017 Nissan Murano AWD SUV (A50324)
2017 Nissan Murano...
2015 JOHN DEERE 35G EXCAVATOR (A51242)
2015 JOHN DEERE...
ATLAS 84" BOX BLADE (A51243)
ATLAS 84" BOX...
Killbros 385 Gravity Wagon (NICE) (A50774)
Killbros 385...
