Shear bolt needed?
   / Shear bolt needed? #1
Anonymous Poster
Epic Contributor
I recently bought a quick hitch for my JD 5310 and really enjoy the easier attachment of implements. Yesterday brought a new problem, however.
My tiller, which I use only once or twice a year, goes on fine, but the PTO shaft is too short. This shaft has a shear bolt at one end. In the past the shear bolt has broken when the tiller would, for example, dig up a rock.
I have another shaft from another implement that I could use, but there's no shear bolt.
So, my questions:
1. Can I safely use the other shaft without the shear bolt? My gut tells me "no".
2. I saw a PTO extender at TSC. It looks like it fits on the shaft of the PTO on the tractor and sticks out about 18", more than the 6" I need. Is this a safe and a practical solutions?
Thanks for your thoughts.
   / Shear bolt needed? #2
Re: Shear bolt needed?...or Slip Clutch Upgrade!
<font color="blue">… a PTO extender…</font>
Hi Doug,
The PTO extenders are available in “different lengths”, made for your type of situation… /forums/images/graemlins/smile.gif
<font color="blue">… Can I safely use the other shaft without the shear bolt?...</font>
On the implement end, the connecting yoke assembly will either be splined (no shear bolt) or smooth (with shear bolt)… and they can’t be interchanged…
You need some form of attachment method… which is yours?
Also, before you “cut down” the drive shaft from another implement, you will want to consider “if it will still be long enough” for the original implement it came with… /forums/images/graemlins/blush.gif
<font color="blue">… PTO shaft is too short…</font>
Have you considered, “adding a slip clutch” to this "short" drive shaft, solving many problems… at once… /forums/images/graemlins/wink.gif
   / Shear bolt needed? #3
</font><font color="blue" class="small">( My gut tells me "no". )</font>
I think you're right, but I'm sitting here trying to picture what you have. There are at least two shear bolt arrangements I'm familiar with and haven't noticed any PTO driveshafts without either one of those two, or a slip clutch. So it sounds as if the two driveshafts you are talking about are not alike and the second one may not even fit onto the tiller. Of course I could be wrong; I just haven't been able to picture in my mind exactly what you have.
   / Shear bolt needed? #4
Doug,
You need the extension sold by TractorSmart. See this recent discussion about your exact problem. /forums/images/graemlins/cool.gif
All - Thanks for your prompt response.
Bill - You're right. The previous discussion is exactly on point. Thanks.
(10) 28' Continuous Fencing Panels (A50515)
(10) 28'...
2006 GMC C7500 DUMP TRUCK (A51406)
2006 GMC C7500...
John Deere 693 Corn Head (A50514)
John Deere 693...
2011 Manac 36245B30 43ft T/A Walking Floor Trailer (A50322)
2011 Manac...
2018 Toyota RAV4 Hybrid XLE AWD SUV (A50324)
2018 Toyota RAV4...
2018 Ford F-150 4x4 Ext. Cab Pickup Truck (A50323)
2018 Ford F-150...
