Shear bolt madness
   / Shear bolt madness #1
rbarker
Platinum Member
Massachusetts
BX 25
I broke another auger shear bolt on the right side of my 2750d blower last night. Still not sure why it broke but that's beside the point. I can't get the old bolt out. I finally gave up at midnight after kneeling in the snow for about an hour. I'm pretty sure I found the right spot because everything lines up right but I can't seem to drive the old bolt out. I tried a Philips head screw driver (an old one that I don't care about) and something that's worked for me in the past a 16 penny nail. It shouldn't be that hard to drive the bolt out, should it? What am I missing here? I must be doing something wrong.
Any help of suggestions would be greatly appreciated.
Sent from my iPad using TractorByNet
   / Shear bolt madness #2
Can you try it from the other end of the bolt?
   / Shear bolt madness #3
When you put the new in be especially careful not to over torque the nuts and contribute to their early demise. I buy a bag of each (fan and auger) for mine at the dealer.
   / Shear bolt madness #4
Bob, I lost the same shear bolt a few days ago on my 2750D and I found the old shank using a nail. The auger moves side to side quite a bit and I had to slide it to the right, towards the blower center to find the old shank. The old shank came out with ease.
Dean
   / Shear bolt madness #5
If your using bolt w/nut try nylon threaded nuts,just snug nut to washer don't over tighten.
try flat punch just hair smaller than bolt your trying to remove from there side..bolt may have bur which catching.
   / Shear bolt madness #6
do you use a hair brush to brush your teeth?
get a set of punches and drifts. event he cheap 9$ set from harbor freight witht he nice fake leather case. comes with chissles and punches from 1/2" down to pin punch size.
well worth the money!!!
once you get the shank out.. look at the hole to see if it is egged.
post back
I did but there's not enough room to swing a hammer more than a couple of inches.
I did buy a dozen or so auger bolts and a half dozen fan bolts. When I do get the new bolt in I'll pay careful attention to how much torque I tighten it to. I haven't used a torque wrench before but I will now.
Bob, I lost the same shear bolt a few days ago on my 2750D and I found the old shank using a nail. The auger moves side to side quite a bit and I had to slide it to the right, towards the blower center to find the old shank. The old shank came out with ease. Dean
Yeah, that's pretty much what was trying to do and I've had success in the past with that technique. I'm hoping that maybe the daylight will help. I at work now but will try later before it gets dark.
do you use a hair brush to brush your teeth? get a set of punches and drifts. event he cheap 9$ set from harbor freight witht he nice fake leather case. comes with chissles and punches from 1/2" down to pin punch size. well worth the money!!! once you get the shank out.. look at the hole to see if it is egged. post back
Yeah Soundguy,I deserve that! LOL a set of punches is in the immediate future. Thanks guys for all the suggestions so far. I will update as soon as I get a chance to get back to it.
LAMAR 20 T/A TRASH TRAILER (A50854)
LAMAR 20 T/A TRASH...
2017 JLG Skytrak 6036 6,000LB 4x4 Rough Terrain Telehandler (A50322)
2017 JLG Skytrak...
2020 INTERNATIONAL LT625 DAY CAB (A51222)
2020 INTERNATIONAL...
2015 CATERPILLAR 259D SKID STEER (A51242)
2015 CATERPILLAR...
2016 LINK-BELT 235X3 SPIN ACE EXCAVATOR (A50854)
2016 LINK-BELT...
2018 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A51222)
2018 FREIGHTLINER...
