Sharpening "step type" drill bits
   / Sharpening "step type" drill bits #1
Kubota-guy1911
Glenarm, IL.
Kubota L2501, Kubota BX2350, IH Cub Cadet 1450, Cub Cadet (Diesel) 1572
I'm getting to where I have a drawer full of dull step type drill bits, also known as the Uni-bit or Vari-bit. Has anyone had success re-sharpening these bits? If so, what diameter and shape of griding wheel did you use?
kj
   / Sharpening "step type" drill bits #2
I may be wrong, but I believe that the sharpening is done with a special sized wheel which make a cut on the trough of the bit to make a new cutting edge.
   / Sharpening "step type" drill bits #3
I have a bunch also and wondered what I'll do once they become dull{some allready are}. On regular drills I just use my grinding wheel, been doing that for well over 20+yrs, never had an issue. I've thought maybe a dremel or something small might work on the step drills, but would take a looooong time.
   / Sharpening "step type" drill bits #4
If you can find a machine shop that has an old Brown & Sharp tool grinder they should be able to do it. The cost might be more than the value of the tool. I would try using a Dremel on the back side of the cutting edge to clean up the edge. This will only work until you grind it back past the center of the cutting edge then it will start rubbing instead of cutting.
Dan
   / Sharpening "step type" drill bits #5
I use a Dremel with a thin cutoff wheel to sharpen all my bits. Paddle bits, auger bits, and step.
   / Sharpening "step type" drill bits #6
Good question, I've got 4 of them now still cutting fine, my first thought was no not practical, but maybe with a Dremel like mentioned. They must be pretty hard, and have a complex cutting edge, I doubt you would get them like new sharp.
They are the only bit I've found that can drill cast iron pipe, especially making the pilot hole, I've tried everything from cobalt to carbide, but the step drill is the only one that works, once the pilot hole is in they open the cast iron right up effortlessly.
Out of necessity I've become quite proficient at drill bit sharpening, everything from 1/8" HS to 2" carbide core bits. When my step bits get dull I'll have to give it a try.
JB.
Thanks guys for the idea's. I'll try my dremel tool or die grinder. I like these step drills in my drill press to, especially the one that can handle material up to 3/8". After lining up a precise pilot hole, drilling up to 1/2" hole is right on the money.
kev
   / Sharpening "step type" drill bits #8
Ive sharpened my old one several times but they usually are not quite the same. Ive been very good at hand sharpening standard drill bits and started practicing on my old step bit. It does need a different type of stone to do it very well. I chain saw sharpener might just work well if you can find a way to hold the bit steady as the angle of the cutting edge is slightly under cut I used a rounded over 4.5" metal grinding wheel on my 4.5" hand grinder that worked so so. The stone on the chain saw sharpener will work much better.
Mark
   / Sharpening "step type" drill bits #9
Cutting oil will help extend the life of any cutting tool. In the machine shop the motto was "Always keep a cool tool"
Dan
   / Sharpening "step type" drill bits #10
I know Sears sells a fixture to hold router bits to sharpen them with a router and a grinding wheel with a 1/4 dia. shaft. You slide the router bit back and forth across the wheel to sharpen the back side of the router the same as the step drills. The sears model number is
25169. This is an old number but the fixture was called (Sharpening Attachment for router and shaper bits) http://www.owwm.com/pubs/222/1487.pdf Check the last page fig #7
2009 Mack Hood (A44391)
2009 Mack Hood...
2017 Chevrolet Tahoe SUV (A42744)
2017 Chevrolet...
2006 CHEVROLET EXPRESS SERVICE VAN (A43003)
2006 CHEVROLET...
2020 Chevrolet Malibu LS Sedan (A42744)
2020 Chevrolet...
PALLET OF 3 DEF TANKS (A45046)
PALLET OF 3 DEF...
2014 LOAD TRAIL GOOSENECK TRAILER (A45046)
2014 LOAD TRAIL...
