Sharpening blades on the mower
   / Sharpening blades on the mower #1
Johntodd
Ripley, TN
Cub Cadet LTX1050
Hi! Just did my first deck removal / blade sharpen on my LTX1050.
Everything is fine, all nice and balanced.
Whew! Is there an easier way to sharpen blades w/out removing the blades and the deck?
Thanks!
-Johntodd
Oh Lordie!
Say it ain't so....I gotta do this EVERY TIME?
Oh well. I didn't let 9-11 stop me, I won't let this stop me either.
-Johntodd
   / Sharpening blades on the mower #4
dunno if it works for you in yer situation, but some keep an xtra set of blades on hand - sharpened, balanced, ready to go on short notice...
   / Sharpening blades on the mower #5
That's why mine only get done every five years !!!! (we only mow Jan-May),
as for 9/11, well at least one grub won't be causing the planet any further heartache,still not enough for those who perished R.I.P.
   / Sharpening blades on the mower #6
Thanks!
-Johntodd
Yes! There absolutely is!. It is called the Trade-In Program. Might be a bit tough on the wallet to buy a new mower whenever the blades get dull, but it is much easier on the back. :D
   / Sharpening blades on the mower #7
Ok, there is an easier way. You don't need to remove the deck to remove and sharpen the blades. With a floor jack and jack stands, you can probably raise the mower to about a 30 degree angle. Then, wedge a chunk of wood between the deck and blade and use a big breaker bar to take the bolt out.
Once you do this a couple of times and get used to doing it, it's not a hard task at all.
I'm not familiar with that mower, but if it has grease zerks, make sure you have the right setup to get to all of them without removing the deck. When you don't ever take the deck off, you can neglect lubrication.
   / Sharpening blades on the mower #8
Oh great, thanks a lot. You reminded me that I need to sharpen my mower blades. :laughing:
   / Sharpening blades on the mower #9
John don't be discouraged it gets easier each time you do it.
Wedges are a big help when it comes remounting the deck and never seize on the spindle threads helps too.
I wanted a real close cut so with the use of some red lock tight I fitted a few washers between the blades and the spindles...now I can quickly sharpen the blades without taking them off with an angle grinder.
UPDATE:
Ok, I've done it a dozen times now. Broke the deck belt, replaced it. Sharpened blades, fixed a thing or two. You were right, it's easier now. Just pop it off, do the work, and pop it on. I've lost my deck virginitidy. :)
2016 CATERPILLAR 239D SKID STEER (A51242)
2016 CATERPILLAR...
2016 Big Tex 24ft. T/A Flatbed Trailer (A50322)
2016 Big Tex 24ft...
1988 CATERPILLAR 815B PADFOOT LANDFILL COMPACTOR (A51242)
1988 CATERPILLAR...
BUNDLE OF USED GALVANIZED CORRUGATED METAL SHEETS (A51244)
BUNDLE OF USED...
Lot (4) 16' Light Duty Pipe Gates (A50515)
Lot (4) 16' Light...
PALLET OF WALL PACKS (A51244)
PALLET OF WALL...
