the old grind
Elite Member
- Joined
- Jul 21, 2012
- Messages
- 4,405
- Location
- Mid-Michigan
- Tractor
- NH T-1520 HST, NH TC33DA HST, Case DX26 HST, .Terramite T5C, . NH L785
I'm not happy with the flow & pressure of my shallow well and pump. Where I notice the loss of flow and pressure is when hosing off a tractor or when filling the Maytag. I'm always good until the bladder tank is empty, and then flow slows to a trickle (my terms). Showering is not a problem, as my WH and/or pump can cycle on and off well ahead of the low-flow shower head I use. (often feel the water warming as I stand there ...) This has been the norm since I bought the place and after replacing pump & tank 10 yrs ago, WH <5 ago, so IMO it's the system and not any component that sets my limits.
Here's what I have:
Shallow well with crock/cistern ~50 ft from acres of pond, and nothing but sand anywhere near my former gravel pit property.
3/4" copper on all lines serving more than one fixture, and 1/2" to each per std practice.
Sta-Rite FNC-L 1/2 hp pump, 30-50 switch, in a 'pump room' indoors with pump on top of tank.
All 1 1/4" lines from pit to pump.
Bladder tank (~30 gal physical size, IIRC 12 gal draw down) pressure is checked yearly and hasn't needed topped-up more than a lb or two.
Whole house filter that when element is changed makes no obvious improvement in flow/pressure.
Low o'all demand in daily use, washer, kit sink, shower, and once in a while the hose to rinse a machine or fill a bucket.
What I like to have is 40-50 psi (regulated, metal 'indoor' CSV, or similar) and better flow o'all, but ... as I understand it a SW pump can't be counted on to put out much pressure regardless of head. (8'-12' max suction, <10' vert, <60' to furthest fixture)
I'm considering upgrading to a 3/4 hp pump, and not sure it wouldn't take 'forever', like my Sta-Rite, to deliver the last 10 psi to tank. I'd settle for 40psi constant if flow would keep up with anything besides the shower.
Right now I'm looking at a Hallmark (ebay) and a Red Lion (Amazon), both 3/4hp shallow well models. GPM claims are wide for these and others, and of course there's a trade-off between flow and pressure. Cost is of little matter, and flow demand won't be much more than current use. 'Quiet' would be a big plus, as my house is usually silent when the fridge isn't running or the HVAC making it's usual dim roar.
Please comment if you think I could get 2-3 gpm at 40 PSI with only a pump change (to 3/4hp, w/CSV) or if there's something I'm missing in planning the upgrade. As always, digression from topic is fine, esp if we learn something. Thanks, guys. tog
Here's what I have:
