Shaft power calculations
   / Shaft power calculations #1
freedomlives
Platinum Member
Husak, Slovakia, EU
Iseki TS35F, Goldoni Special 140 with powered trailer -- Goldoni Special 128 -- Goldoni Uno for mowing -- Czech Vari system
Anyone know where there's some table of how much power a shaft can transmit? I've got to make an adapter for my two wheel tractor's PTO to attach a different manufacturers accesories, one of which is a cutterbar mower. I've got the two toothed couplings, and I was about to weld some thick pipe of the right length when it occurred to me that I'd rather use a thinner, mild steel rod, because if by chance something hard (like metal stake, particularly) gets caught in the teeth of the mower, its going to come to a hard stop, and better the PTO coupling breaks/bends than something inside the gearbox of the two wheel tractor (which I just replaced some gears that were stripped from the previous owner and presumably something with the snowblower, which had sheer bolts of a relatively high grade that probably hadn't sheered...)
I "feel" like 10mm rod ought to be about right, but what do I know?
Tried some other search terms, I guess I can go from this:
Relationship of torque and shaft size - Plant Engineering
D=sqrt( (P*105)/R )
My gut feeling seems about right. 5HP @3000RPM is the motor on the machine the attachments are from, so that works out to .41 inches, or 10.6mm
SKIDPRO  SKID STEER GRAPPLE (A52472)
SKIDPRO SKID...
80in HD Tooth Bucket with Side Cutters ONE PER LOT (A52748)
80in HD Tooth...
2006 V.E. ENTERPRISES 130 BBL STEEL VACUUM TRAILER (A52472)
2006 V.E...
New Long Forks (A53002)
New Long Forks...
JOHN DEERE 608C (A53084)
JOHN DEERE 608C...
