bjr
Veteran Member
What the end goal is. To be able to make my own grass catcher bags for garden tractor mowers. The OEM bags are out sight expensive for what they gotta do. So the mesh type onion sacks are readily available and what I'm gonna do is sew two sets of two sacks end to end or overlap a little then cross lay the two sacks in a cross then sew up the edges in a box with a open end. The sacks are approximately 22 x 33 inches. I will make my own rectangle frame out of some lightweight 1/2" tubing to attach to the catcher top hanger. My sewing idea is to use like long knitting needles or small diameter rod with a drilled hole to pull the twin thru the mesh. Just kinda every two inches or so (skip sewing). The idea for the mesh is so the mower air flow goes thru the bag and the lawn clipping goes to bottom of the bags. Any idea on twine type (braided fishing line maybe)? What style or kind of needle would be best? I'm kinda thinking about using some corrugated tin with slots cut across the corrugation to make kind of a loom. One piece of corrugation laid on top of the other with material sandwiched between then shove to needle thru the slots with the twine attached to make the joint. I'm tryin' to make this simple and quick to make replacement grass catcher bags. Any imaginative souls out there? Kind of a cottage industry type deal. Ideas welcomed. bjr
