Sewage Pump
   / Sewage Pump #1
RobS
Super Member
Goshen, IN
None!
I need some help understanding the electicals on a sewage pump. I happened upon a used one from a friend and it should work as a replacement for my sump pump in the basement for the bathroom that I have added.
He had used this pump for an outdoor water garden and didn't use the switch. I confirmed that the pump works when plugged in directly. The switch is a seperate 110V line with a male/female plug. The pump plugs into this plug.
The switch itself is a black plastic, round can with holes on the bottom. It is fixed to the side of the pump by a bracket. There appears to be a diaphragm inside the can which does operate the pump when I push it by hand. I can also hear and feel a click.
My current pump has an enclosed float switch that likely has a mercury switch inside as the pump is triggered when the float rises and changes angle.
I assume the water pressure will push the diaphragm on the new pump but how much water? I have it in a wash tub but it's not deep enough. Is this entire pump really submersible? I'm concerned about the electrical feeds going into the pump and switch. Do I just need more water depth to trigger?
Any help appreciated!
   / Sewage Pump
Got it figured out. It's called a diaphragm switch and it works just fine. I didn't have it in deep enough water. Apparently, no issue with fully submerging the pump. Good info here . I'm working on the hookup now, got a bit of a shower taking the old pump out so I'm drying off!
   / Sewage Pump #3
one thing that I would worry about is that most of these pumps are not designed to be used a a fountain pump which he used it as so it ran for how many hrs? if it is free/really cheap then no biggie but if you are buying at a good price then maybe think now many hrs have this pump run and how many are they rated to run???
mark
   / Sewage Pump #4
After install I would definitely test it- ya don't want to go downstairs and find a lake Also maybe you should refer to it as a sump pump. Actually sewer pumps have stainless steel impellers to grind the sewage up and run into the thousands. Last one I bought was $1700.:eek: -Ed
   / Sewage Pump
I had thought of that Mark but he said they didn't use it long as it didn't have the flow they wanted. I ran it before the install and it seemed fine. And yes, the price was exactly right... free!
2000 Mercedes-Benz S-Class Sedan (A55758)
2000 Mercedes-Benz...
2015 Ford Taurus SE Sedan (A54815)
2015 Ford Taurus...
UNUSED SWICT 84" QUICK ATTACH BUCKET (A54757)
UNUSED SWICT 84"...
2012 Volkswagen Jetta Sedan (A55758)
2012 Volkswagen...
2018 Ford Fusion Hybrid Sedan (A55758)
2018 Ford Fusion...
2015 Chevrolet Silverado 2500 HD Crew Cab Pickup Truck (A53422)
2015 Chevrolet...
