Backhoe Setup for digging with the BH on a BX25
   / Setup for digging with the BH on a BX25 #1
Chugbug
Central Ohio
BX25
I've got a dumb question on setting up the BX25 BH for digging. When setting the FEL do you use the blade tip to raise the front of the tractor up? When I 1st got the machine I was told to basicly dump the bucket and set the blade tip into the ground and raise it so that the front tires are just off the ground. I've noticed on several videos that that sat the bucket level on the ground to lift the front. I've been setting the blade to raise the front, then setting the stabilizers on the back. Hope this is OK, no damage to the bucket???? Help
   / Setup for digging with the BH on a BX25 #2
Well, the simple answer is, I don't have a simple answer.
Depending on conditions of soil and terrain, I can say it varies. If I am going to be digging in one spot for a while (which with a BX24, I usually am digging for a while), I tend to dig the edge in just enough to provide a more solid anchor point. I typically just add enough pressure to keep the tires touching but with most of the weight off of the tires. With the bucket tip in the ground it will help some with dragging the tractor around when using the BH. While the BH is slow, it is powerful, so with hard ground this can help.
If the ground is soft and I am going to be doing a lot of moving, I just set the bucket on the ground flat and don't worry about trying to use it as an anchor point.
The more you use it, the more you will figure out what works good for you.
I never use it to try to level out the tractor if on a hill, and I never dig pointing down the hill with the BH.
   / Setup for digging with the BH on a BX25 #3
Right or wrong , I can only tell you what I did. Working on a very steep hill diggin out some pretty sizable stumps , I dug the blade tip in , on more level ground I just raised the front wheels with the bucket level.
Seemed to work well for me.
Whew, makes me feel better, I was afraid I may end up bending......but it seems it does not make a huge difference. Thanks for the quick reply's!
2015 CATERPILLAR 305E2 CR EXCAVATOR (A51242)
2015 CATERPILLAR...
80in HD Tooth Bucket with Side Cutters ONE PER LOT (A52128)
80in HD Tooth...
2013 VERMEER RTX1250 RIDE ON TRACTOR (A51242)
2013 VERMEER...
2007 MACK GRANITE  TRI-AXLE DUMP TRUCK (A51222)
2007 MACK GRANITE...
2012 UTILITY VS2DX 53FT DRY VAN TRAILER (A52141)
2012 UTILITY VS2DX...
2023 MAXXD TDX Drop-N-Load Trailer with Air Ride Suspension and Tilt Deck (A52128)
2023 MAXXD TDX...
