kvmapr
Bronze Member
I took the plunge this Spring and bought a 5 foot King Kutter II Tiller to pull behind my Jinma 254. I managed to get it mounted and put a nice finish on the garden plot, but in doing so I came across a couple of set up issues that I wanted to seek your collective advice on...
The first has to do with the adjustments for the skids on either side of the tiller. I noticed the right side skid could be raised one more position (bolt hole) to get the tines deeper into the ground (so I did, see photo 1 below). But on the left hand side of the tiller I can't set the skid to that deepest position because the oil bath housing is in the way. There's simply not enough clearance (see photo 2 below). Anyone else have this problem with their KK II tiller?
Photo 1 - Right side skid has been set into the deepest position (the lowest bolt hole).
Photo 2 - left side skid can't be set to deepest position because clearance between skid and bottom of oil bath housing is too narrow (probably just 1/2 inch, when 1 inch of clearance is needed).
I'll start a second thread for the other set up question I have. This is enough for one post.
Thanks,
KVMAPR
Thanks,
KVMAPR
