Setting up rotary cutter on JD2305
   / Setting up rotary cutter on JD2305 #1
JCCinOhio
SW Ohio
JD 2305
Just got a used RC 2048 for my JD 2305. Never used one before so just checking that my thinking is right... I have the 'rockshaft lever' and 'rockshaft rate of drop control lever'.
Am I wrong in saying there is really no way to limit the rear arms from dropping their full extent? In other words, the only way to adjust the depth of cut is to stop the drop using the rockshaft lever, and then shut off the rate of drop knob so it doesn't bleed off lower?
   / Setting up rotary cutter on JD2305 #2
JCC, you have that just about right. That was one of the shortcomings of the JD2305 in particular and subcompacts in general (with an exception here and there). Eventually, you do get used to adjusting it on the fly though and it is not all that big a deal.
2025 KJ K1230 UNUSED (10) Wire Mesh Netting Rolls (A50860)
2025 KJ K1230...
2004 Porsche Cayenne AWD SUV (A48082)
2004 Porsche...
MAXUM 1000 TRIPLEX PUMP POWERED BY 3412 CATERPILLAR ENGINE (A50854)
MAXUM 1000 TRIPLEX...
2021 Delta Redirective Crash Cushion 75000 (A48081)
2021 Delta...
2013 MAGNUM TRAILER GENERATOR TRAILER (A50854)
2013 MAGNUM...
2011 MACK GRANITE HOT OIL (A50854)
2011 MACK GRANITE...
