Setting up carburetor idle position of governor after new carb install. Husky 22HP twin B+S, Engine #44R677, Type# 0021677, Nikki dilution carb.
   / Setting up carburetor idle position of governor after new carb install. Husky 22HP twin B+S, Engine #44R677, Type# 0021677, Nikki dilution carb. #1
subby
westbrook CT
sears suburban
Installed a new Zenni dilution carb which has a manual choke and a adjustable idle . The tractor has the combined throttle and choke control. Far front is choke and back is speed control. It has the standard engine governor . Choke position functions properly, but the throttle is forcibly held held in the open position, it will not assume the idle position, as the actuating arm is being held in the open position by the constant positioning spring in the mechanism . The throttle cable stops 1/2" from the idle adjusting screw.
I examined the mechanism and cable adjustment will not fix the situation I tried resetting the governor, as to contact the idle speed screw. I t wouldn't budge. As it stands the governor/actuation arm would have to be bent to give any extension for the idle position, or forcibly repositioned. There has to be a common sense solution to achieve the factory settings/control with out a 5# hammer?
Thanks,
Subby (SS525, Cuba patrols)
   / Setting up carburetor idle position of governor after new carb install. Husky 22HP twin B+S, Engine #44R677, Type# 0021677, Nikki dilution carb. #2
I have no idea what a Zenni dilution carb is, but a couple of tips on what goes wrong as it pertains to the OEM> First know that there are different OEM carbs for these. One has two holes in the throttle arm, the other one. If it won't idle down there are a couple of assembly mistakes that can cause this. 1) the throttle link only goes one way to clear the manifold. 2) The metal gasket looking thing is called a swirl plate. If it is flipped around, it could interfere with the throttle plates.
In the end there is only one way to set the governor. Google static governor adjustment or hit us back if you need to.
2013 MACK GRANITE (A52472)
2013 MACK GRANITE...
NEW HOLLAND 706 30 INCH 3PT DIRT SCOOP (A52748)
NEW HOLLAND 706 30...
2017 E-Z Beever M12R Towable Brush Chipper (A51691)
2017 E-Z Beever...
JOHN DEERE CP 770 (A53084)
JOHN DEERE CP 770...
2013 INTERNATIONAL PAYSTAR DAY CAB ROAD TRACTOR (A51406)
2013 INTERNATIONAL...
2013 Chevy Silverado 2500 HD (A52748)
2013 Chevy...
