IHDiesel73L
- Joined
- May 13, 2010
- Messages
- 167
I'm putting up a 6' dog ear privacy fence around my backyard-about 400 linear feet total. We will likely sell our house in the next 10-12 years so what I would like to do is put up and largely leave it alone aside from washing/painting it every so often. I'd also like it to still look good when we go to sell so that it's a selling point rather than something that is seen as needing to be updated/replaced eventually. I'm not so concerned about the panels themselves-I'm building them myself and spraying all of the components twice-once before they go up to coat all sides, and once after they go up to seal the whole panel. I'm using three 5/4x3x8 rails per section and stainless steel nails-everything will be pressure treated of course.
My biggest concern is the posts-my neighbor has an old stockade fence that was up before he bought the place and the infamous "landscape timbers" (the ones with the rounded sides that Lowes tries to pass off as pressure treated on sale sometimes :laughing
were used instead of pressure treated 4x4s. They're twisted, they lean in spots, etc...which I'm trying to avoid. They're also concreted in. I've heard a lot about ways to make fence posts last a long time so I wanted to go through and list some of the things I've heard here so that other members can comment on what worked (or didn't work) for them.
- Setting posts in gravel - I've been hearing this one a lot. I get that gravel promotes drainage which prolongs post life, but what kind of gravel? How small? How deep should the posts be sunk? I was going to go 2', but in my mind I'm imagining that a 4x4x8 sticking 6' out of the ground wouldn't be all that sturdy set in two feet of pea gravel. I should also add that we have very heavy clay soil here if that makes a difference.
- A footing for the post - Much like with pole barns I've heard of people using a "footing" at the bottom of the hole (like a cheap concrete paver), but others say use gravel at the bottom of the hole to ensure that moisture doesn't sit at the bottom end of the post where it will wick its way up.
- Treating the buried portion of the post - First off I planned on treating the entire post with a water sealer prior to setting it anyway, but I've heard of dipping the buried portion of posts in driveway sealing tar to further water proof them. Still others say you should paint the tar on and leave the bottom uncoated so that moisture can escape through the bottom if need be.
- Sealing the tops - This is a no-brainer. I'm going to buy the little copper "hats" for the tops of the posts because they will weather nicely.
If you've got any other tips for making a wood fence last 20 years, lay 'em on me!
