Setting 2 speed Motion Match
   / Setting 2 speed Motion Match #1
prowley
Monroe, WA
John Deere 3520 Cab
I have the motion match button, I have read the manual, and I have even set motion match to different speeds, but... how do I change the "other" speed? My motion match button gives me the same roll out no matter whether it is set on short or long. The instructions for setting motion match in the manual are not clear to me on this and I am only able to set one speed.
Here's what the manual says:
"Changing MotionMatch Setting
1. Press and hold the display mode switch until the display reads Release?
2. Release the display mode switch and display should read Coast?
3. Press the display mode switch once again.
4. For machines without MotionMatch switch:
a. Push the turn signal switch and return to neutral position to change to desired setting between 1 and 9. Position 5 is displayed as DEF? the factory default.
5. For machines with MotionMatch switch:
a. Push the turn signal switch and return to neutral position to change to desired setting between 5 and 9. Position 5 is displayed as LONG_D? the factory default.
b. Push the turn signal switch and return to neutral position to change to desired setting between 1 and 5. Position 5 is displayed as SHRT_D? the factory default.
6. To confirm the changes for MotionMatch setting, press display mode switch once again. "
What is really not clear to me is what decides when 5a. is done and now I'm on step 5b - it's exactly the same, push turn signal up or down and return to nuetral to move one setting. Mine seems to act more like 4a., in fact it shows "DEF" at factory default.
After some searching here it seems that my dealer forgot to update the display panel to account for the switch. Does anybody have instructions for setting this up? I think it may be in the technical manual which I don't have yet.
Unfortunately the threads that allude to this don't actually list the instructions to do it.
Western Snow Plow with Brackets (A50515)
Western Snow Plow...
2019 BOBCAT T770 SKID STEER (A51242)
2019 BOBCAT T770...
DIRT DOG RC104 4' ROTARY MOWER (A51243)
DIRT DOG RC104 4'...
71053 (A49346)
71053 (A49346)
2 Wheel Wagon / Cart (A50515)
2 Wheel Wagon /...
2023 JOHN DEERE 30P TIER EXCAVATOR (A51242)
2023 JOHN DEERE...
