Servicing my new used tractor (Oil Change)
   / Servicing my new used tractor (Oil Change) #1
kdcvsc
Kubota L3400
I recently purchased a 2005 Kubota L3400 4WD with 722 hours. I changed the oil this weekend andonly about 3 quarts drained out. Its supposed to take 6 so I'm not sure if there is an issue. I ran a quart of new oil through and then refilled with 4 quarts. The dipstick is reading right in the middle where it should be and the oil on the dipstick looks clean now. Should I be concerned that I couldn't get 6 quarts to drain out? I removed both plugs and the filter and took of the cap to facilitate a good flow. I didnt' know what else I could do to get out the rest of the oil. This is my first tractor.
   / Servicing my new used tractor (Oil Change) #2
There are a few threads here on that issue. It seems few folks are able to actually put in the 6 quarts the manual states. Most find 5 to be just about right.
Thanks BP. I'll see if I can track down these threads. I'm still concerned that I couldn't get near the 5 quart range.
   / Servicing my new used tractor (Oil Change) #4
Does the 3400 have two drain plugs?
   / Servicing my new used tractor (Oil Change) #5
also, fill the oil to the top mark of the dipstick (but not over). every little bit helps. you may want to consider changing all fluids since it is used. it's a pain, but provides a lot of peace of mind. and, you'll learn a lot about your tractor.
   / Servicing my new used tractor (Oil Change) #6
Yes it does!!! Did you drain both sides?
I just re read the OP and he mentioned removing both; didn't catch it the first time, oops.
Will do Tibbits. I've already lubricated the tractor and FEL and plan to change out the fuel filter and the Hydraulic filter. I was told by the original owner that he recently had to refill the hydraulic fluid when he had a hose bust and all the fluid leaked out. It doesn't look like he change the filter though which I thought was odd. I plan to replace the front axle case oil as well but I need to figure out what type of oil goes in there first. Is there a secret to getting the oil into the check plug? It looks difficult.
   / Servicing my new used tractor (Oil Change) #8
sounds like a good plan. you can use sudt in the front axle, but I've read threads where folks say gear oil is also ok and may have some benefits. I use sudt for simplicity (always have some around).
refilling the trans fluid is a pain due to the fill hole location and angle. there are some threads on how to rig a solution. best I recall, I used a flexible funnel and wire and a lot of grunting lifting 5 gal buckets of sudt. I think next time I will buy a small transfer pump. others say it makes the job simple and I seem to be seeing other uses for a pump. they're cheap from what I've read. should save a lot of time and oil spills.
also, be sure you get the new sudt2 when you change fluids. I think most dealers have this now, there are threads on it. I still have the 'old' sudt but plan to switch to the new at next fluid change. I don't like to mix fluid types, even if it's ok to do so.
I also assume you have the dual element air filter. the inner element is an emergency filter in case the outer one fails. you don't have to change the inner, but I did when I bought the tractor.
I also flushed the radiator. it was clean, but at least I know it was clean. if you do it, it can wait until you're in the mood.
one last little thing, get a turning knob for the steering wheel if it doesn't already have one. cheap but makes a big difference.
   / Servicing my new used tractor (Oil Change) #9
almost forgot, after you change the front axle fluid, check it frequently for a while. it can take a little time for the fluid to work into all the spaces in the axle.
   / Servicing my new used tractor (Oil Change) #10
since I was in your shoes not long ago, I have to mention the best benefit I have found on TBN. it's not how to get the most from your tractor, but how to live long enough to do so.
these machines are a lot of power in a small package and can make your wife a widow in 3 seconds. read the posts on this site about fel safety and roll overs. it's amazing how easy it is to get in a dangerous situation on a tractor. wear you set belt while your new to it all and remember even experienced drivers are routinely killed or maimed.
don't want to scare you, but a good dose of fear early may not be a bad thing and should evolve into a healthy respect as you get used to your machine. if you ever become fearless, you'll one day be reminded... with a blushed white face and soiled undies as you teeter in 3 wheels.
Ford 18in. Stock Rims (A53117)
Ford 18in. Stock...
10" Shaver Post Driver (A52384)
10" Shaver Post...
UNUSED LANDHONOR PHA-16-2C HYD HITCH ADAPTER (A51248)
UNUSED LANDHONOR...
UNUSED RAYTREE RMAU2 AUGER (A51248)
UNUSED RAYTREE...
(2) 7' ATV RAMPS (A51248)
(2) 7' ATV RAMPS...
UNUSED WOLVERINE PFA-11-3300G HYD PALLET FORKS (A51248)
UNUSED WOLVERINE...
