Servicing 4120 trans fluid
   / Servicing 4120 trans fluid #1
whitedogone
Central Illinois
JD 4120
OK...I have close to 400 hrs on the 4120. I go to the dealer and get a price on low vis hy-gard and filter. $250 :mur::mur:
   / Servicing 4120 trans fluid #3
Somethin's not right with the math here... I'd have to guess that the $250 charge is for the dealer doing the maintainance work - drain, clean sump screen, change charge filter, replace inline filter and refill. Yes?
All you would do show up with the tractor - or does that include pickup and return of the tractor to your place?
If delivery is part of the equation - your dealer is losing money!
Hydraulic oil is around $60/5 gallon pail. You need around 10 gallons - eHydro transmission.
2 filters @ $55. That comes up to about $175.00 more or less.
Again, if the dealer is doing the work or if that includes tractor delivery... it's not all that bad a deal at all - and if they're delivering your tractor - get on the phone right now... 'cause he's losing money!!! :D
AKfish
   / Servicing 4120 trans fluid #5
Low-viscosity hydraulic oil in my area is about $90 for a five gallon container & that is at multiple dealers. Roughly $70 for a hydraulic filter, so it's coming up about right.
2020 Nissan Rogue SUV (A51694)
2020 Nissan Rogue...
2012 JOHN DEERE 160G LC EXCAVATOR (A52705)
2012 JOHN DEERE...
2017 FREIGHTLINER CASCADIA SINGLE AXLE DAY CAB (A54607)
2017 FREIGHTLINER...
STOW One Tonner Tandem Smooth Drum Roller (A52377)
STOW One Tonner...
2003 Ford F-250 4x4 Reading Service Truck with Liftgate (A53422)
2003 Ford F-250...
Sakai SW880-1 (A47477)
