Dirt Moving Service needed?
   / Service needed? #1
BoFuller
Veteran Member
Arizona
2008 Kubota L3400
I plan on using my L3400 about 8 hours a day for a couple weeks as I prepare my new ranch for occupancy (making a drive, a pad for a cabin, a pad for trailer, a pad for 40 ft container, etc). Should I be using a grease gun on a daily basis, weekly, monthly? I take delivery of the tractor in about a week. A 2008 L3400 with 63 hours.
   / Service needed? #3
I like to grease my tractor every 10 hours at least.I grease the bucket pins on the loader and backhoe at least once a day and sometimes twice if I am using it a lot.These are the ones that seem to take the most abuse and wear the quickest.It is hard to over grease.
   / Service needed? #4
I grease my tractor by the manual, but grease my implements each day.
   / Service needed? #5
For what its worth, every morning before you start, pull out the grease gun and give a few shots. The price of grease is cheap compared to parts and labor and down time. When i had my backhoe, it was greased every day and the gun stayed on the machine, in plain sight. I have found if its in sight you think to use it .. . John :thumbsup::thumbsup:
   / Service needed? #6
I'm in the "Grease is cheap, Pins are expensive" group.
If you are using it everyday for 8hrs a day you should be greasing it every morning.
2015 FREIGHTLINER CASCADIA (A53843)
2015 FREIGHTLINER...
2025 SDLANCH SDLE20 UNUSED Mini Excavator (A53117)
2025 SDLANCH...
Lincoln Electric Flextec 450 Welding Machine (A53117)
Lincoln Electric...
Hay Trailer (A53117)
TRANSMISSION JACK (A53843)
TRANSMISSION JACK...
2011 Mercedes-Benz E550 Sedan (A51694)
2011 Mercedes-Benz...
