service manual
   / service manual #1
ket1954
southern ohio
yanmar 1802D
anyone know where I can get service manual for a 1802D.. thinking I have a blown head gasket and would like some spec's
   / service manual #2
I just bought a service manual for my 1802. Actually it is a manual for a 220, 220D, 226, 226D but it is supposed to have the same info. What specs do you need? You can order it from Hoye.
   / service manual #3
Welcome to TBN!:D It is hard to get a service manual exactly for the grey imports, but they can come close with a manual for a "made for America" Yanmar. In mine there are some major differences. For me the the 186 has many different features than my 1510D. The front axle is totally different, hydraulic connection, etc, but the basic engine and such is the same.
You can get the "equivalent" manual from almost any of the dealers that frequent this forum, Hoye was mentioned, but also LMTC in Ohio, EFC in Washington State, and many others.
Mike
   / service manual
need torque specs for everything from the head up. I'm blowing oil out on exhaust manifold side , not sure if its the head or coming from exhaust manifold as it also looks like its leaking oil in fitting going up to muffler.. maybe seal on valve or something and I will be able to repair only pulling valve cover.I'm have never worked on any diesel motor. this motor has never run hot, I don't do much more with it than mow pulling a 5' finish mower only mowing about 2 acer now days , used to mow around 5, tractor is really over kill, drag the drive once a month with a 4ft box ( about 1400ft) but its all level and I don't really put a strain on tractor.
I have no power lose, no excessive smoke, no over heating but getting a black oil mark on side shield. I have taken real good care of this tractor since I have had it with all the regular filter and fluid changes, has just over 900 hr on it now
2019 MDB FM180 FINISHING MOWER (A51247)
2019 MDB FM180...
Duetz Power Unit (A50120)
Duetz Power Unit...
2011 Ford F-150 4x4 Ext. Cab Pickup Truck (A51692)
2011 Ford F-150...
2019 INTERNATIONAL LT625 TANDEM AXLE SLEEPER (A54607)
2019 INTERNATIONAL...
RIDGID POWER DRIVE/HAND HELD THREADER (A53843)
RIDGID POWER...
