Service Intervals for TN tractors
   / Service Intervals for TN tractors #1
kmanvt
Bronze Member
Hiltons, VA
I need to know what service should have been done on a TN75A tractor with around 210 hours on it. I believe I'm going to get the tractor, but wanted to make sure the service was up-to-date on it.
   / Service Intervals for TN tractors #2
TN service intervals are much longer than compacts. If I remember right, oil at filter at 50 and then every 300 hours. Hydraulic filter at 50- no fluid change. First hydraulic fluid change is 1200 hours. Grease everything every 10 to 50 hours depending on what it is and how much it moves. ie loader joints every day, steering stuff about every 50 hours. Also check wheel and other mounting bolting tightness carefully. Don't forget those grease fittings on axles and hubs. Do you have a manual. If not you need to get one. Very easy machine to service.
Andy
2018 Ford F-150 4x4 Ext. Cab Pickup Truck (A50323)
2018 Ford F-150...
2007 Toyota Camry Sedan (A50324)
2007 Toyota Camry...
2019 BIG TEX GOOSENECK  TRI AXLE 34FT 2 CAR HAULER (A52576)
2019 BIG TEX...
2015 DODGE RAM...
2002 Blue Bird F131612 Bus (A51692)
2002 Blue Bird...
2024 JOHN DEERE 331P-TIER SKID STEER (A51246)
2024 JOHN DEERE...
